The Guz
- Jun 17, 2013
- 8,793
- 69
Thank you Meghan for sending these out to me for review.
Products: Blackfire Pro Detailers Choice Advanced Pad Cleaner, Blackfire Pro Detailers Choice Citrus Pad Cleaner
After polishing my brothers car I was left with pads which needed to be cleaned. It was a good opportunity to use these two products.
These are definitely carryover products from the various PBMG lines. I am familiar with both from the other lines.
I started by soaking the pad with the citrus cleaner mixed with about 3.5 gallons of water. Directions state to use 1 scoop for 3-4 gallons of water. Then let the pads soak in the solution for up to 15 minutes.
Here is a blue pad that my brother was using on the Rupes Mini that was hitting some trim. We all start somewhere. This is a blue HDO pad.
I agitated the blue HDO pad within the cleaner after about 15 minutes. This is how the pad came out. Not bad but could be better.
One thing about the cleaner is that it sometimes will not clean out everything from the pad. But it does help break up any compound, polish or waxes in the pad. Sometimes a pad or pads will need another round of cleaning.
In this instance I reached for the advanced pad cleaner. I sprayed it onto the pad and let it sit for the recommended time. I then massaged the cleaner within the pad and then rinsed it our.
This is what the pad looked like. All clean and like new.
I set some pads aside to clean with just the advanced pad cleaner. This is pretty straight forward to use. Directions state to spray it onto the pad, let it dwell for 30 seconds, agitate and rinse out.
Dirty pads.
After agitating the pads and rinsing them out the pads came out clean. FYI the yellow Rupes pads are stained from the Rupes yellow polish (keramik) as it is gray in color.
Final thoughts:
This is not my first time using either of these products. These are carried over into the new Blackfire line.
The pad cleaner has always worked well for me. It is not going to clean the pads 100% of the time. But what it does do is break down the polish or wax within the pad. Another round of cleaning may be needed. What it won’t do is break down sealants. They are typically pretty durable once in the pad which is a good thing.
The longer the pads sit within the solution the easier they are to clean afterwards. I have let them sit in the bucket overnight with no problems. My pads were easier to clean out. I do recommend rinsing out the pads after taking them out of the bucket. If not you will get citrus powder the next time one uses their pads.
The pad cleaner works very well to clean pads. The first time I sprayed I said to myself they reformulated the cleaner to not have that strong odor. Well after a few more sprays I was wrong. One whiff of it an it aggravated my allergies.
This is the biggest con I have for the pad cleaner. It keeps me from purchasing it. I mean this stuff is literally “toxic” to me. I feel like it burns my lungs along with my allergies. It does it to me when used outside as well. Forget using it inside.
Other than that these two work well together in getting pads clean.
I have included a video of the entire cleaning process using these two pad cleaners.
Dirty pads.
Final thoughts:
