Review - Blackfire Pro Detailers Choice Foam Booster
The Guz
Thank you Meghan for sending this out to me for review.
Products: Blackfire Pro Detailers Choice Foam Booster
Price: $22.99
Quantity: 16 oz
Product Description:
BLACKFIRE Foam Booster is a uniquely specialized formula that, when added to any car wash soap will instantly transform it into a foaming car wash! Using a highly concentrated blend of lubricating agents and advanced polymers, BLACKFIRE Foam Booster enhances the cleaning power of your car soap for an overall safer washing experience. Foam is what makes the car wash perform and with BLACKFIRE Foam Booster, you’ll never experience a foam shortage again!
One of the biggest things that make a car wash successful is the amount of foam produced. Foam creates a sort of barrier between your car’s surface and any dirt and debris, safely removing them before they can scratch or mar the surface.
BLACKFIRE Foam Booster is a foaming agent that will enhance any car soap and give it the perfect amount of suds.
After adding BLACKFIRE Foam Booster to the car wash solution in your Foam Gun, you are ready to coat your car in mountains of foam! Regardless of whether or not your car wash was foaming already or not, after BLACKFIRE Foam Booster it will be!
Contrary to popular belief, not all car soap is created equal. There are wash and wax formulas that leave a layer of protection, ultra-cleaning formulas that strip away any surface protection, and so on and so forth. How many times have you found a shampoo that you love only to find out it doesn’t perform quite as well when used with a foam gun or foam cannon? With BLACKFIRE Foam Booster, that doesn’t have to ever happen again!
BLACKFIRE Foam Booster is not a car wash in itself. It is simply a foaming agent that will enhance the car wash that it’s added to!
Even if the car wash you already have sitting in your garage isn’t a “foaming” wash, after a quick doctoring with BLACKFIRE Foam Booster, it will be!
Keep every car wash you perform a safe car wash with BLACKFIRE Foam Booster!
Directions for use: To transform any standard car wash into a foaming shampoo, simply add Foam Booster to your car wash bottle or to the car wash shampoo already in your foam cannon, foam gun, or wash bucket for an increased amount of suds produced. BLACKFIRE Foam Booster is extremely concentrated – a little goes a long way!
Prior to this coming out there was no product description other than it makes any car shampoo a foaming car shampoo.
I decided to use this on my personal car hoping there was no polymers in it as I am currently testing Sonax CC36 ceramic coating and I don’t want anything to get in the way of my control area on it. Lo and behold the product description page states it contains polymers. I hope they are just there for lubricity rather than staying behind.
It comes in a squeeze bottle. Similar to the microfiber towel cleaners.
Dilutions are listed on the rear of the bottle. As stated on the directions it can be used in a bucket or straight into the bottle of one’s favorite shampoo.
The shampoo I decided to use was CarPro Reset. I use this as my main soap for my personal cars that have some sort of coating on them. Reset foams pretty well on it’s own and has good lubricity as well. I also added Reset into my foam gun with some Blackfire Foam Booster.
I added 2 oz’s into my bucket with Reset. It created suds as I was mixing it by hand in the bucket. More than usual. The Foam booster is thick and I could feel it in the bucket as I was swirling my hand around to mix it all up. I recommend mixing it pretty well.
It did create some nice suds in the bucket.
The directions on the label did not state that it could be used in a foam gun or foam cannon. So I was not sure prior to the product being released and reading the product description. I foamed the car and sure enough it produced a lot of foam. This is with the max setting on the foam gun.
Foam on the rear spoiler.
After a few minutes the foam started to run off the paint. Coated paint is nice as nothing really sticks to it..
I proceeded to wash the paint with a bucket wash and there was still suds in the bucket at the end of the wash process.
This was the second time I used the foam booster. The first time was with Rupes M101 and that shampoo is not designed to foam. The foam booster increased the foam in that and the lubricity.
Final thoughts:
The foam booster has lived up to it’s name in creating foam with any shampoo. Well at least the two I used it with. I am confident that it will do the same to other shampoo’s.
It did add some lubricity to the shampoo. I believe this is due to the polymers within it. I am not sure if the polymers linger around and are left on the paint. It did rinse clean ans as far as I know it didn’t affect the LSP that is currently on the paint.
The only complaint I have is that the product is on the thick side and it's takes a little effort to squeeze the bottle to come up to the measuring cup.
For those that like foam this would be the product to try.
I can not comment on how it works with a foam cannon. A foam gun has it's limitations and the foam won't stick like it does with a cannon. But the foam gun adds some fun to the wash process.
Note: Foam gun used.
Quik question: The directions seem to indicate that 2oz. should be added into a full gallon of undiluted car wash soap, or am I wrong?
You added 2oz. into the wash bucket with what I'm guessing was around 1.5oz. of car soap + 3 gallons of water? Wouldn't that be way too much of the Blackfire Foam Booster?
PBMG - My OCD eye caught a typo that you may want to fix... Warnings 1 and 2 both say "May cause eye irritation"
LOL, I know I know, who reads the warnings haha
Sent from my SM-G955U using Tapatalk
Well that's because you have 2 eyes, and they're warning each of them. Lol.
Assuming here that's a little bottle of SLES?? Sodium laureth sulfate - or am I an ASS?
Well shoot, now I feel like an idiot! Lmao
I don't know why, but I'm thinking of the 3 Stooges, when Moe would block the 2 finger eye poke from Curly... Incorporating that into the warning label, it should read: PREVENTION - Hold your hand vertically along your face, in order to block incoming mounds of suds from blinding you. Lol.
🤣haha, awesome idea. If they use it you can demand products as your royalties lol
Screenshot my post for backup, just in case they try it... I'll make you a partner @40% lol.
Alright lets keep this on topic about the product and not the label.
Nicely done, Guz as always professionally done
As always thanks.
Nice review Mike. Seems like it would make the foam cannon extra fun (especially for new customers). The dilution ratio is a little confusing though. Add 1-1.5oz to a 32oz bottle and 2-2.5oz to a gallon? Guess I'll have to experiment with it to find the sweet spot.
Thanks. Yeah I agree the dilutions are a bit confusing.
@The Guz. So after your experience with using the product, what would you say is the proper dilution/way to use it?
2oz. into my gallon of car wash soap?
Or 2oz. into my car wash bucket + my normL wash soap + water?
The difference in dilution would make it a dealbreaker for me.
My main question is:
Why?
Why do I need this?
This Blackfire Pro line is not impressing me one bit so far.
Why?
Why do I need this?
In the eternal words of Marie Antoinette: let them make foam (or something like that)
I don't think you need it by any stretch. But if you have a car wash soap you like for its cleaning ability and it doesn't foam as much as you like, you can make it foam. I, for example, really like the cleaning ability of a particular pre-soak product but it has never foamer well for me even though it is meant to be used in a foam cannon. This product would allow me to make it foam better.
Also for the guys that love the foam cannon, it's a way to get some extra foam, especially if you have hard water that would otherwise inhibit the foaming.
Why?
Why do I need this?
I think this product is an attempt at innovating, and perhaps establishing a new category of products. Sometimes there are big hits with these type of new innovations, and sometimes there are misses. Time will tell with this one. Do you need a foam booster? No, there are soaps formulated specifically to maximize foam already. Do you need a pad conditioning spray to to prime your buffing pads with? No, you don't really need that either.
Could this product be helpful for someone without a pressure washer but who also has/uses a foam gun? It might. Ultimately, the market will decide. I'm all in favor of BlackFire running this one up the flagpole to see how it flies :surrender:
Interesting product. Thanks for the review.
Thanks.
That depends on how well the soap foams on it's own. One has to find that sweet spot for their personal use.
Lol
Why?
Why do I need this?
Well why not?
See the response from Audios S6. He gets the idea.
Exactly. So far the only one that has gotten the idea of this product :dblthumb2:.
