Review: Carpro Fog Fight - good and bad
SRTSean
After reading another thread on the site mentioning Fog Fight being a royal pain to use I had pretty low expectations for how well it would work for me.
Last night I decided to give it a try and have mixed feelings on the product.
***One note, my windows are tinted and I have no clue if this impacts how the product performs. I didn't apply it to the inside of the windshield because I ran out of time.
Anyways, for prep I cleaned the inside windows using Stoner's Invisible Glass aerosol. From there I went on to applying the Fog Fight using the supplied products.
Fog Fight has a pleasant smell, very similar to Eraser, and the sprayer mists nicely. Three sprays per window seemed to provide more than enough product. No issues there. However, I do have to comment on the microsuede applicators included for product application. I'm not sure if these applicators do anything special that a microfiber towel can't, but they are simply cut too small to be able to easily use in conjunction with the foam applicator block as they barely wrap around the block and stretch in spots as they get wet. I stuck with it, but I probably won't use them next time.
After applying and spreading the Fog Fight I allowed it to cure on the glass for about 10 minutes. I had read that this was one method that could aide in ease of removal. After allowing it to cure I buffed back off using the supplied microsuede towel for buffing. Again, this towel is way too small to use easily. I gave up after two windows and went to a blue, rolled-edge microfiber towel to finish buffing.
The much discussed streaking/film was present everywhere after a first pass of buffing the product off so I decided to using compressed air on the glass to see if it could dry any more. After using compressed air I made a second pass at buffing and found that the glass was now almost entirely streak free (a few small spots required a little more effort to get streak free). Happy with this method, I completed the remaining three windows using the same method and with the same results.
This morning on my drive in I left the defrost off and no fogging of the glass occurred. Not even blowing my hot breath on the glass could get the driver's window to fog. Two thumbs up there.
Final Verdict
The product performs as advertised, but the effort required to apply and remove it is simply too great. I spent 45 minutes just completing 4 windows, not including how long a windshield and rear window would take. I won't toss it in the trash, but I probably won't use it on my personal car again. Maybe I'll give it a shot on the bathroom mirror if I can find a way to bring my compressor inside. :laughing:
Compressed air you say...
I will certainly try this when I get around to applying fog fight.
You may have unlocked the key to this product.
I'd really be interested on what you find when applying to the windshield.
I really like the fogfight on my bathroom mirror. For some reason it dries really well on it unlike my car windows.
Thanks for the review, I found good and bad as well but it didn't take me as long as you found. I think throwing it in the trash is overreaction by some. It is a miracle product on my bathroom mirrors and i still have it on my windshield to this day. I also started using it on my side mirrors on my (kept outside) daily drivers. It stops the condensation from making them impossible to use in the mornings.
hmmm, maybe I'll use my sidekick to help with the curing process
thanks for the review!
-I decided to using compressed air on the glass
-I spent 45 minutes just completing 4 windows
-Wonder if this product actually does behaves differently on "mylar-films" than on:
*Automobile side window glass;
*Automobile windshield glass;
*Automobile rear window glass;
*Automobile rear windows made from: "plastic types";
*Bathroom mirrors.
-Every time you mention, in this scenario, glass/windows...Are you meaning tinted glass/windows?
-Hope the compressed-air didn't create any microscopic pin-holes in the mylar-film, causing an earlier than expected failure to occur. (Maybe that's where 'some' the Fog Fight 'went in', leaving a less-streaking appearance??)
-Sounds like you had to do a whole lot of extra rubbing on the window tint...It's pretty thin to begin with!
-Glad you were successful, as you have described.
-I still don't see the need to "treat" auto glass, whether it's on the interior/exterior. Never, ever on tinted glass, as well.
A dedicated glass cleaner will suffice, IMO. That's probably just me though.
