RevitalizeAutoSpa
- Apr 23, 2014
- 360
Manufacturer description: CarPro Reset Intensive Car Shampoo is a specially formulated shampoo that is designed to gently release dirt and grime without damaging the underlying coating – ie: Cquartz or any other quartz-based nano coating. CarPro Reset Intensive Car Shampoo is extremely concentrated; only an ounce of shampoo is required for an entire 5 gallon bucket of water! CarPro Reset Intensive Car Shampoo creates mounds of thick suds that rinse cleanly off the vehicle.
$24.99 for 1 liter
CarPro Reset is currently my default shampoo for washing my personal vehicles (2002 Infiniti Q45 and 2005 Infiniti QX56) since they're both coated, and any customers vehicles that I've coated.
I typically put about 1.5oz in my foam cannon.
Immediately after foaming:
One minute after foaming:
Five minutes after foaming:
As you can see, it foams well and dwells well. That's with the foam cannon set to maximum chemical.
I also tested it with the Gilmour Foam Gun, which sadly doesn't get much use since I got the SunJoe 2030 and foam cannon.
Performance with the Foam Gun was somewhat below average. It didn't foam nearly as well as Chemical Guy's Honey Dew Snow Foam, Mr. Pink, or Extreme Maxi Suds II.
Immediately after putting in 1.5oz and hitting it with a strong jet.
Amount of foam after three minutes of washing:
Amount of foam after seven minutes of washing:
Amount of foam upon completion, rinse bucket on the right:
Washing in progress:
Pros:
- Good results with a foam cannon
- Does a good job of keeping coating at it's best
Cons:
- Not so great with a foam gun or hand washing
- Fairly expensive - $25 for a liter (less if you've got wholesaler pricing through CarPro or some other detailing websites)
Verdict: If you love suds, it really isn't the soap for you. It still feels pretty slick, but doesn't do as great of a job on some dirt. The Q is garaged, but the barracks behind my company is being reconstructed, so there's constant construction dust on the car. Once it rains, that gets pounded in, and even with the CQuartzUK it takes some work to get clean. The Reset does a good job with the foam cannon, but not so much with a foam gun and hand washing. I think my next shampoo will be Chemical Guy's Citrus Wash.
Rating: 3 stars out of 5
