The Guz
- Jun 17, 2013
- 8,792
- 67
Thank you Avi for sending this product for review.
Products:
CarPro Tire Swipe Applicators
Cost:
$19.99 for 8 applicators
Product description from Autogeek
CarPro released this applicator in 2018.
The description is pretty straight forward with this tire applicator. It has a firm foam handle to prevent any tire dressing or protectant from getting on ones hands. The handle has the new CarPro logo imprinted on it for added aesthetics.
The foam applicator is cut to the shape of a tire to avoid from any tire product from getting onto the wheel.
The applicator applied the tire dressing evenly without any streaking. CarPro Perl at 1:1 was used in this particular case.
One thing to be aware of is that this applicator struggles on the raised areas such as getting tire dressing into the upper portion of the tire as seen in the photo.
The other thing is the applicator tends to apply product towards the center of the applicator and on the outer edge of the applicator. So the tire product will need to be worked in evenly.
For smoother tires they have no issues.
Overall these tire applicators work well and the best part no tire product all over the hands.
One thing I would recommend is to label the applicator with whatever tire product it is used with. It will become your dedicated tire applicator for that particular product.
Thanks for reading.
Products:
Cost:
The CarPro Tire Swipe Applicator was designed to make applying a tire dressing to you tires as easy and efficient as possible. There are so many different types on tires and wheels out there that it can be difficult to find an applicator that is able work effectively on all of them. It is for this very reason that the Car Pro Tire Swipe Applicator was designed with a unique asymmetrical radius that allowsyou to apply a tire dressing or gel to the outer edge of your tire without covering your rims in the stuff!
You will experience a noticeable increase in durability when you compare the Car Pro Tire Swipe Applicator to other tire dressing applicators that are on the market today. The CarPro Tire Swipe Applicator was designed with a tough steady grip handle, so it can stand up to repeated use and abuse!
The CarPro Tire Swipe Applicator is made with a much denser foam that keeps more of the dressing or gel on the surface of the tire. This means that your tires are able to absorb more of your dressing and you will receive better results from your chosen tire protection! Whether you want your tires to be matte black or high shine, the Car Pro Tire Swipe Applicator will make sure you get the best finish your tires have to offer!
Thanks for reading.
