REVIEW: Creeper seat for detailing!
Dr_Pain
2,196
I've seen the subject of work stools being tossed around quite a bit lately , and read many opinions and preferences. Obviously I do have some of mine as well. It does seem that the same opinions are tossed around, but no real breakdown comparison is being offered. I would like to take this opportunity to present the subject and interject my opinions in the matter, and would like to present my argument discussing the:
1) Ergonomics
2) Cost
3) Construction
4) and Function
Being a physical therapist by profession I do support heavily the "proper ergonomics" argument, but if you were to ask my "complete" opinion on the subject this post would be a lecture that could get quite hairy. Trust me this review does not need to be that complication since we are all looking for the same thing, that is a cheap, safe and functional tool which we can abused day in day out, and replaced economically (if need be). I've evaluated several seats over the years, from the cheapo Harbor Freight option to the most expensive Kreepstool, and came to an honest conclusion on the subject. Here is what I have tried so far
1) Standard creeper seat (I believe it was from Sears for around $25)
2) An adjustable pneumatic creeper seat (from Harbor Freight for about $25)
3) An adjustable Traxion (purchased online $125)
4) Kreepstool (borrowed valued at $180)
**One I wanted to try before writing this review was the Racatac but at $225, I did not see the value of the investment despite the ergonomics
Without dragging this review let me give you my winner and personal recommendation, that is the Northern Tools "Big Red" seat (made my Torin), which can be purchase for $50 (less if you use the discount coupon). But WHY?? In evaluating all of those seats I evaluated them for cost, function and ergonomics, and I feel the Torin "Big Red" was the best without breaking the bank.
Here is a side by side of 3 creeper seats I have in my shop (two of which are destined for the landfill)
attachment.php
So what makes it a winner??
Construction:
  1. Chrome plated heavy gauge steel square tubing
  2. Plastic tray insert
  3. Allen head flush bolts with lock washer
  4. Sealed bearing 3 INCH wheels
  5. Wide padded seat
  6. Bottle holder/cupholder
  7. Max weight capacity is 400lbs
If I was to expand on the list above this is what I would say about it: It is made of chrome plated steel which will tolerate the constant environmental exposure, regardless if it is sprayed down by accident, or doused in chemicals. A plastic tray insert is provided for tool storage, which won't corrode if water is allowed to sit for days or if you have an inadvertent product spill. The same can't be said about the HF cheapo seat. Unlike some of the more economical seats, this seat uses Allen head bolts which is much better than the cheap nuts which tend to back out with use. Unlike most seats, this particular creeper is set on 3" wheels which are much more functional then the standard 2" which are only rated to 250 lbs. To be honest, the bottle holder is a nice added bonus (and useful) but extremely flimsy. The rest of the seat on the other hand is SOLID. For those questioning the fact that I am not considering an adjustable height seat, let me be honest and say that I NEVER use that function (and neither does most people I spoke to). A backrest would be good, but how many times do we opt to sit in our creeper and lean back on the back rest??? In terms of function the Big Red seat rolls with great ease. It is not as easy as the Traxion to roll over extension cords, but it is definitely better than the five wheel HF cheapo (which every caster tends to go in their own directions <--- what a pain)
At $50 it is almost 2x what I would pay for the HF cheapo, but its value is self evident in the fact that I normally have to replace a seat/year (because the wheel bearings fall apart or gets chewed up so bad). At 6'6" and 235lbs I am close to the max for the cheapos, whereas the Big Red is rated to 400lbs.
As you can see from the pictures included there is no real comparison in the quality. You can also see the quality of the wheels
attachment.php
attachment.php
attachment.php
attachment.php
From the picture you can see there is a slight difference in height between all of them (less than 1"). While detailing, the lower you get the less bending at the waist you have to do, however there comes a point when the position of "knee to chest" (from sitting so low) becomes functionally hindering.
attachment.php
attachment.php
attachment.php
My rear is definitely appreciative of the extra width of the seat but not as much as with the extra padding
attachment.php
attachment.php
Do I have anything bad to say about the seat? Surprisingly I don't. I like its heavy construction, 3" sealed bearing caster (rated for heavy loads); I like the wide, well-padded seat and height. I like the fact that it has a plastic tray and that it is chrome plated for durability. Although the bottle/cup holder is pretty flimsy, it is usable and functional .
So why would I even consider purchasing a Kreepstool for 4x the price, or a Racatac for 5x the price? Well, I would not!!!! The Kreepstool sits too high to do most wheel well and wheel work. It does have a decent amount of storage, but I have a habit of never storing much stuff in my creeper seat because it will invariable get sprayed as I go around the car with the power washer. The seat back is ergonomically preferred (under perfect conditions) but would only be used in very select seated position (for resting). Polishing a panel sitting in the Kreepstool still requires you to lean forward to put the machine on paint and to apply down pressure so the backrest becomes a non-issue.
When selecting a creeper seat, you have to consider its realistic applications, and to be honest I do not see the cost/benefit value of any seat above $50 as they WILL get abused and will need to be replaced. Conversely, you get what you pay for. To decide on a $25 stool from HF which is not rated for normal oversized people makes no sense either. Best to spend a little more and get something you won't have to replace yearly.
Hope you enjoyed my review. Here is a glamor shot of the stool in action over the weekend. Note the CarPro red masking tape which I will review, and the PF2500 (my preferred compound) sitting nicely in the cup holder.
attachment.php
I loved the review, I just did not see any pictures. This is a great review as I have been considering a seat, but have no clue which one to purchase. Thanks for posting this.
Funny I see them all?? Let me see if I can fix them. They are part of my CarPro forum gallery. Would they be blocked? Hang on, the next post will have the review reconstructed with the pictures hosted on AGO
1) Ergonomics
2) Cost
3) Construction
4) and Function
Construction:
Plastic tray insert
Wide padded seat
I have (and regularly curse at) the "little" red (Sears?), bought at Canadian Tire on sale for $15 about 10 years ago. It is indeed flimsy. Every so often while working on a car I'll find an extra self-tapping screw on the ground, and after a minute of head scratching I realize it's one of the screws holding the thin Masonite seat to the frame. If I were using this seat daily for work, I doubt it would have lasted a week.
I saw all the pix in the original post, possibly because I have CPF cached and open in another tab...
I guess that could be the problem. May need to be a member of the CarPro forum to have access to the library!?!! Oh well, it is reconstructed now with the pictures hosted on AGO:Picture:
Nice review. I've been using my Autogeek bucket as a creeper seat for years, but recently found this one on their website:
Kreepstool Rolling Utility Seat, Kreep-stool creeper, creeper seat
That is my new want for sure. The bucket works ok, but it doesn't have the storage for anything. I don't like putting my machine on the floor sometimes because I've got clients with treated floors and I don't want to mark them up or stain them with the pad. Anyway, it is on my list to get something like this sometime.
The Kreepstool is definitely top of the line in terms of construction BUT way too high. As explained in the body of my review, the storage is a nice concept but in term of function and practicality, I can't see paying the extra for it. If you use your creeper seat the way I do in cleaning wheels and rolling around the car taking care of running boards or fender wells etc... you will find that you will want to keep the least amount of "stuff" in the caddy. It is not uncommon that I use a Speedmaster (cleaning wheels) and sling back all over the front of my creeper seat. When that happens (not if) you would have a bunch of contaminated towels and such.
Made in U.S.A. Awesome seat for detailing and mechanical work.
The TailBone is a great looking seat and one I did consider. Large wheels, polypropylene plastic construction , "Made in America", and with a weight capacity of 350lbs..... but no tool tray and also $130 + shipping.
If you look at their vids, you will see that they don't use the backrest :)
True about using the back rest, but it sweet.
Very nice review Claude. I think you did well pointing out getting the best bang for your buck. This after all is a very important aspect to consider. Sure anyone could spend the extra for the nicer seat but that extra money would be more beneficial towards another tool.
Thanks for taking the time to review something that most of us would never think of reviewing or taking the time to put it together for others to see. This is one of those areas that tends to be over looked when it comes to detailing.
Interested to see more about that red tape. If you could, include the green 233+ in your review.
I received, as a gift, some years ago the red Griots rolling seat. I am on my 3rd set of wheels and have found those are the key for me. I upgraded the casters when the originals wore out from a local caster supply place and they made a huge improvement. The wheels are simply post mounted into the bottom and are easily removed and replaced.
GREAT recommendation, Claude, and thanks. It looks like you've found a good, substantial and relatively inexpensive product for something we all put some use and abuse too!
I too wanted to do a caster swap but found that its cost plus upholstery and seat cushion was almost as expensive as getting a new seat ($50 + coupon discount), not to mention that the fixed creeper seat is not exactly the sturdiest for a big guy like myself. The piston on the HF cheapo was failing so never fully extended it and those 5 wheel set ups (and center piston support) are DANGEROUS. 4 wheels is better for stability and to maneuver and I am sure the Tailbones design with 3x5" caster is even better.
