sparkie
- Aug 9, 2006
- 5,357
1. Clean and dry the surface to be treated. (I did)
2. Apply liberally with soft cloth. (I did with a sponge)
3. Allow to dry. (I did)
4 Buff with a soft cloth for added gloss. (I Buff with an old cheap MF, works better with MF then terry cloth) Boy did it ever gloss up.
This was applied to plastic, rubber and black paint.
When I apply it for the first time it was nothing like other dressing. It streaks and just plane look weird. I let it dry, and buff off with MF. The harder I buff the glosser it got. I was impressed. Now will it run in the rain, I will let you know?
Duragloss Rubber & Flat Black Dressing (RBD) #271
Enhance and restore flat black trim and bumpers!
Duragloss Rubber & Flat Black Dressing contains a blend of polymeric synthetic polymers in a solvent base. RBD #271 cleans and shines rubber bumpers and moldings, and is recommended for flat black surfaces.
Duragloss Rubber & Flat Black Dressing is a low luster silicone dressing for flat black automotive surfaces, such as the bumpers and moldings. Its solvent base lifts old dressings in order for the silicone polymers to bond better with the rubber. Once applied, Duragloss Rubber & Flat Black Dressing enhances the dark color and restores the like-new luster to these surfaces.
Duragloss Rubber & Flat Black Dressing is water-resistant and will not wash off in the rain once cured. The finish is a low-gloss sheen that complements the paint, rather than overpowering it.
Duragloss Rubber & Flat Black Dressing is a great way to enhance the most weather worn parts of your vehicle. Dark rubber bumpers and moldings are often neglected and tend to fade quickly due to UV exposure. Duragloss Rubber & Flat Black Dressing restores the lost color with long-lasting, waterproof polymers.
Instantly restore the color and like-new luster of faded rubber bumpers and flat black moldings with Duragloss Rubber & Flat Black Dressing.
