REVIEW - Diamondite Clear Plastic Kit for headlights
blkyukon
I've tried many different products for cleaning headlights - metal polish, paint polish, plastic polish, etc.and all work great at restoring headlights. This weekend I tried the Diamondite's Clear Plastic Kit for headlights....I have to say, this kit is probably the most effective product I've used so far, (everything you need is in the kit ) plus the 4" pads makes it much easier to work on headlights.
The kit includes:
  • Diamondite Clear Plastic Enhancer w/ 4" Yellow Cutting pad
  • Diamondite Clear Plastic Restorer w/4"orange Light cutting pad
  • Diamondite Clear Plastic Liquid Armor
  • backing plate & Drill adapter
  • Microfiber Towel
Machine used:
I used a rotary set at 1800prm for both the Enhancer and Restorer....A drill (set at~1800rpm) or a PC (set at~4500-5000opm) will work just as well -a PC will just take a bit long to break down the polish.
Method - The main thing to remember when working with plastic is not let it get too hot. Getting it too hot could cause the plastic to cloud.
First, mask off any surrounding area with painters tape. Apply the Enhancer to the pad and work it in using slow overlapping passes, using moderate pressure until it becomes translucent - remove residue with MF towel. Depending on the severity you might need a couple of passes before moving to the next step.
I found the Enhancer to be very effective at removing the majority of clouding and surface scratches with just one pass...With further testing I found it will also remove 2000 grit wet sanding marks in one pass too.
After removing the imperfections, change to the orange pad and apply the Restorer to the pad and work it in, using little pressure until it also becomes translucent...again repeat this step if needed.
Note - allow time for the headlight to cool between steps or passes.
Finish with 2-3 coats of Clear Plastic Liquid Armor for protection
Here are some before and after shots:
Before:
Afters:
I have the Wolfgang Plastik Lens Cleaning System, it works great also. My kit came with the orange and black 4 inch pads only.
Great review, thanks for sharing.
Nice. Really appreciate your review. Like Sparkie I've got the Wolfgang Plastik but will be less afraid to try it now that you told us about the machine speeds.
WOW, amazing.
i remember doing the wet sanding routine a while ago, which isnt too hard, but this kit makes everything so much easier!
Very nice, thank you for sharing Charles.
Sweet! thanks for the review. I have some of that stuff and headlights that need some work. Glad I picked some up.
Holy Shnikeys!! They look brand new!! Awesome write up, BlkYukon and awesome results! :applause:
I used the Liquid Armor Protection , great for nice looking headlamps that you DONT want to look like those in the first pic.
OLD thread I know... but I'm running low on my Diamondite headlight kit... Just went to autogeek and noticed they don't sell this anymore???
Why? Anyone know where to get it... or is there a better kit out there? I have had ZERO issues using this kit, it just works 100% of the time.
-Nigel
-Nigel
I don't know about the kit, but I think this is the replacement for the Diamondite plastic cleaner:
McKee's 37 Plex-All aerosol plastic cleaner,plastic polish,clear plastic cleaner polish,DP plastic polish,plastic protectant,headlight cleaner
FYI Meguiars has a new headlight protectant (it used to be sold only in their kit):
Meguiars Keep Clear Headlight Coating
