Wors
- Jun 15, 2012
- 783
In a recent order I picked up some of the New DP AIO Headlight Restoring Polish. Test subject is a Subaru with oxidized headlights and tail light.
Products used:
Before - Front Right
After - Front Right
Before - Front Left
During - Front Left
After - Front Left
The DP Polish and Foamed Wool Pads did an amazing on the headlights. Very little polish was needed and the Foamed Wool Pads were cleaned after each section. Before the after pictures the lights were wiped with CarPro Eraser.
For the tail light I switched to the Griots 6" and a heavy cutting pad to see how well a foam pad would work.
Products Used:
50/50 - Tail light
Conclusion:
The DP polish paired with the Foam Wool Pad or heavy cutting pad cut right through the oxidation and finished down great. All lights were sealed with Optimum Opti-Lens Permanent Headlight Coating for long protection.
Products used:
- Porter Cable 7424XP
- LC-43-073DA Dual Action 3 Inch Flexible Backing Plate
- DP AIO Headlight Restoring Polish
- LC 3 1/4 Inch Thin Foamed Wool Pads
- CarPro Eraser
- Optimum Opti-Lens Permanent Headlight Coating
After - Front Right
Before - Front Left
During - Front Left
After - Front Left
Products Used:
- Griots Garage 6" Random Orbital Polisher
- Meguiars 5" Backing Plate
- Yellow Heavy Cutting Pad
- CarPro Eraser
50/50 - Tail light
Conclusion:
