Review: DP GR4 Graphene Coating
What is it?
A surface coating made from graphene-oxide resins.
What does it do?
Seals surfaces with a super strong graphene-oxide resin layer of protection.
When do I use it?
After washing, drying your car, then performing any paint correction needed and then after using a panel wipe to prep the paint for the graphene coating.
Why should I use it?
To provide rock-hard protection that also leaves the finish feeling smooth and slippery while making future washing and drying faster and easier.
From the manufacturer
Enter the world of graphene coatings with DP GR4 Graphene Coating. Featuring graphene-oxide resins and emulsions to create a rock-hard barrier of protection. The protection of DP GR4 Graphene Coating works on paint, glass, chrome and more. DP GR4 Graphene Coating has a self-cleaning affect that will easily repel dirt, water and other contaminants, creating a water beading power that will reveal a slick and glossy surface. Plus, DP GR4 Graphene Coating is easy-to-apply and will last you up to four years of protection.
But what exactly is graphene? Graphene is the strongest material known to man; you may know it is as graphite. Imagine it as a honeycomb sheet, thick with carbon atoms. So, the automotive world likes graphene because it can easily be added to plastics, metals or other materials to make it stronger.
Compared to ceramic coatings, graphene reduces heat on the surface of your paint, so water spotting is even less likely. And that honeycomb designed we mentioned earlier? That design allows for a high contact angle for water to bead off easier.
DP GR4 Graphene Coating enacts up to four years of protection on your surfaces. This protection is thanks to graphene-oxide resins and emulsions that when combine create a rock-hard, microns-thick barrier. Not only is the surface protected from environmental harm, but also a slick, deep glossy shine. Graphene is known to impart a wet, glossy appearance after all! Plus, DP GR4 Graphene Coating adds tremendous hydrophobic properties. Because of the high contact angles in graphene, amongst other properties, DP GR4 Graphene Coating will allow for water to bead up and roll off, rather than stick around creating water spots.
Another benefit of DP GR4 Graphene Coating is its anti-static or self-cleaning properties. One of the properties of graphene allow for electrical and thermal conductivity, simply meaning that it can easily repel dust and other micro particles, keeping the surface free of build up of dust and other contaminants. This makes it easier for daily or routine cleanings.
Best of all, DP GR4 Graphene Coating can work on a variety of different surfaces, including paint, glass, chrome, trim and even plastic headlights.
Apply DP GR4 Graphene Coating to your vehicle once you have washed, dried and corrected any paint issues. It's also best to use a prep spray, like DP Coating Prep Spray to remove and lingering oils that will hinder proper bonding. Once you're ready, apply several drops of DP GR4 Graphene Coating onto a microfiber applicator and apply back-and-forth in a 3x3 square foot area. Let it set for 1-2 minutes and then remove with a clean microfiber towel. After an hour, you can apply another coat, but let the surfaces sit dry for 24-48 hours for optimal results.
DIRECTIONS
-Wash, dry, and correct paint if needed.
-Shake well before use.
-Use DP Coating Prep Spray to remove any oils that would prevent proper bonding.
-Apply several drops of product onto a microfiber applicator and apply to a 3 x 3 sq. ft. area in a back and forth, cross-hatch pattern.
-Allow for slight overlay to ensure even coverage.
-Allow area to set for approximately 1-2 minutes and gently remove excess product with a clean microfiber towel.
-A second coat can be applied after approximately 1 hour.
-Keep coated surfaces dry for 24-48 hours for best results.
Test car - 2017 Mercedes-Benz C300 4Matic AMG
This beautiful Mercedes-Benz belongs go a good friend and good customer. It's actually his wife's daily driver. I ceramic coated this car about 1 year ago. Since coating this car, if they haven't hand washed it - they've taken my advice and only taken the car through "touchless" car washes to avoid spinning brushes, dirty floppy swirling mops or even dirty wash mitts that come with a 100% Hand Car Wash. The results are incredible. There's hardly any swirls, scratches or even light marring anywhere on the car. BUT - there is some type of bonded contaminants all over the outside of the car and also some type of film that is impacted onto the car. So to the casual onlooker - she looks brand new. But to use car guys, the finish quality is lacking and something needs to be done to restore the finish to pristine and pretty again.
Here's my 7-step process,
  1. Waterless Wash using SONAX Glass Cleaner.
  2. Mechanically decontaminate with detailing clay and SONAX Glass Cleaner.
  3. Machine polish all paint, glass and aluminum window trim - I used the CBEAST with RUPES CP Foam Pads and 3D One.
  4. Chemically strip using a 3D Wipe.
  5. Install the GR4 Graphene Coating.
  6. Machine clean and dress the tires with Pinnacle Rubber & Vinyl Cleaner and Conditioner.
  7. Hand clean the wheels.
Towels used were my new favorite - The Rag Company FTW or For the Windows orange microfiber towels. I use them for everything - not just windows.
Here's prepped and ready to machine polish
NOTE: Look at the finish quality in the picture above. Looks good huh? Now look at the first picture of the car below - see the difference? See how the paint is actually crisper, glossier, wetter looking? It's one thing to take a neglected car to a respected car. It's actually more difficult to take a car in really good contion to a HIGHER LEVEL. Everything must be perfect. The process, your skills, everything. Otherwise - there will be no difference.
Back to the topic at hand...
The only way to remove the film on the car, glass and trim is to machine polish. This will also remove all the previously applied ceramic coating. A must-do in my opinion and experience.
Here's the results...
She came out BEAUTIFUL!
And she's showing a little attitude in this shot...
Review
I wasn't sure what to expect as this is the first graphene coating I've used, at least the first graphene coating that comes the normal way most of us think of a coating and that's a thin, liquid in a tiny glass jar. Like most ceramic coatings, it's clear and thin, almost like water. It spreads out super easy. I let the coating rest for about a minute per treated panel and then gently wiped that section to both level the coating and remove any excess and then moved onto the next section. It took about an hour to coat this Mercedes-Benz working carefully and timing the flash time.
Leveling and the final wipe-off was easy, no sticking or smudging of the coating to the paint. The results were perfectly clear, perfect looking paint. And after wipe-off the finish felt smooth and slick, unlike a lot of ceramic coatings.
The gloss was insane!
I was hesitant to use this new technology on a customer car. I checked with Andre, he's my co-worker that does all the pre-testing of new products. He's really grown into his new responsibilities for testing products here at Autogeek. I trust his judgement. When I asked him about this coating and let him know what I was going to use it on - he simply said,
It's a really nice product, you'll like it.
How long will it last? I don't know, that's the problem with this type of product review. The car I used this on is gone. I have asked the owner to AVOID taking the car through touchless car washes. While in theory it sounds like a good option for those times you can't do a normal water hose and bucket wash in your driveway. But the down side is - these types of car washes tend to use stronger chemicals to loosen road film and dirt since NOTHING is going to physically touch the paint to clean it.
While these harsher chemicals may not remove the coating - I "think" they are responsible for making the anodized aluminum trim surrounding the windows look horrible, spotted and splotchy. I apologize I did not take any before pictures, I know better. But I was in a hurry to crank this detail out. So I didn't take any before pictures of the splotchy looking aluminum trim. I did take some after pictures and all I can say is this trim looked HORRIBLE before I buffed it out. Now it looks brand new.
I coated the trim, but this type of anodized aluminum trim is sensitive to chemical corrosion - thus the reason I've asked the owners to not take this car through any touchless car washes.
In 6 months and then again in a year, I'll check with the owners to see how the coating is holding up and then update this review. That's the best I can do folks. But if the data about this coating is factual and accurate - this coating will do a great job of protecting the paint and my guess is this car will still glisten and look amazing as long as the coating/car is hand washed and dried.
If you're new to coatings, don't fear trying out this graphene coating as your first venture into the coating world. It's super easy to use. If you're a seasoned professional or an experienced enthusiast and you've heard a lot of chitter-chatter about graphene, I'd say go for it. Get a bottle and take it for a test drive. After having used in on a really nice automobile, I agree with Andre,
On Autogeek.com
Crystal clear, insane gloss and shine...
Thanks Mike. The car looks great. Is there any reason why the DP coating line didn't go with the 50ml bottle size like the Blackfire Black Edition, PBL Ceramic Pro and Wolfgang Profi. Is it due to keeping the cost down?
Thanks, beautiful color too...
I have know idea? I'm not part of the marketing team or meetings.
Maybe it's enough to do an average car and like a LOT of coatings, once you open the bottle - whatever you don't use has a limited shelf life before it becomes unusable?
Just a guess.
:dunno:
Just a guess.
:dunno:
Good guess, Mike. A 50ml bottle of most coatings can do two mid-size cars. If your doing just one car, 30ml should be able to do two coats on the horizontals and wheels.
How much did you use?
Just a guess.
:dunno:
Thanks Mike. Was thinking the DP line was to be the more affordable line compared to the other Autogeek house brands.
True. But with a 50ml bottle one could apply two layers to all the paint, wheels, side and rear glass. Especially those with a large truck or SUV.
Most newbies tend to go a bit heavy with their first coating application.
I tried Car Pro UK 3.0 last year and its worked out well. Even if this product lasted 2 years it would be a good value. The UK works in Wisconsin winters in terms of durability on a properly prepared car. I bought a 2021 black Camry SE Awd and want to keep it in great shape. Thoughts on Gr4 (risk on hours of work to not last as long) vs carpro Uk?
I sometimes wonder how much testing of products is focused on hot sunny southern weather vs the temperate ice cold to hot sunny northern weather.
Mike,
In your review you mentioned to the owner not to use car washes (even touch-less, I interpret).
“How long will it last? I don't know, that's the problem with this type of product review. The car I used this on is gone. I have asked the owner to AVOID taking the car through touchless car washes. While in theory it sounds like a good option for those times you can't do a normal water hose and bucket wash in your driveway. But the down side is - these types of car washes tend to use stronger chemicals to loosen road film and dirt since NOTHING is going to physically touch the paint to clean it.
While these harsher chemicals may not remove the coating - I "think" they are responsible for making the anodized aluminum trim surrounding the windows look horrible, spotted and splotchy...
...I coated the trim, but this type of anodized aluminum trim is sensitive to chemical corrosion - thus the reason I've asked the owners to not take this car through any touchless car washes.”
I agree with the advice as a general practice. But am also curious as to whether the advice is only due to the anodized trim, or are you also concerned about the chemical resistance of this coating? Will touchless washes wear on this coating more so than other big name coatings (which I would expect are barely/not weakened by occasional touch-less washes)?
Just wondering if you have any inside info that would make avoiding automatic washes a higher priority for this Graphene coating in particular.
Thanks in advance!
I applied this to a small section as part of my coating test. I have to say that it is on the slick side. For those that are looking for a coating that offers some slickness instead of the typical tacky coating sensation then this is it. For those that have used Gtechniq Chrystal Serum Light, Cquartz SiC or the previous Cquartz TiO2, GR4 is a tad behind in the slickness aspect.
Application is easy. Slight rainbowing.
I finally got around to cleaning my truck 2 weekends back. It was 3 years since I last polished/coated it with CQuartz and it was due for some new protection. The paint wasn't in bad shape because I really try to keep up with it, so I didn't need much. I washed with foam canon, hit it with IronX, Nanonskin fine sponge, hit it with Gyeon Polish on my CBeast with a white pad. Followed up with a good IPA wipedown and applied the GR4. It goes on different than other coatings I've used before, seemed almost like a sealant type feel than a coating. It is definitely slick when finished and really shines.
Mike,
My advice had to do with the anodized trim.
No, not that I'm aware of.
Thanks in advance!
No other insight except that anodized aluminum trim is really difficult to fix once it becomes stained. So for most people, if you have a car that has anodized trim, my advice is to avoid touchless car washes and also iron remover.
Good questions, thank you for asking.
:cheers:
That's the primary reason I like it, the slick feel.
Nice looking truck!
Is that a factory color?
:dblthumb2:
Thanks Mike. Yep, factory Paint, True Blue Pearlcoat! It shines real nice and looks like a mirror to see my other favorite blue in the background, WRB
Can you develop high spots with coating similar to what can happen with a ceramic coating. If it does develop a high spot do you have to polish the sot to remove it?
