Review - DP / McKee`s Paint Coating
Vegas1
Active member
It was time to get my 10 year old daily driver Infiniti G35X ready for winter. So I finally decided to use the DP/McKee`s paint coating I've had for awhile. Just a bit nervous as this was my first attempt at a coating. But after reading all the comments about how easy it was to use, I decided to give it a try.
Before applying the coating I took the following steps.
Wash with 3D Pink Soap
Clay with Nanoskin Autoscrub Speedy Prep Sponge – Fine Grade
Polish with Wolfgang Finishing Glaze 3
Prepped with Wolfgang Perfekt Finish Paint Prep
I decided to use a plain yellow foam pad and it worked out great. This coating was super easy to work with. If you ever used Opti-Seal before, you`ll have no problems at all. It spreads, flashes and even smells like Opti-Seal. I should also mention no high spots at all during the process. After 12 hours I decided to give it another coat just in case I missed any spots. I`m super pleased with the results. Super glossy and super slick is the only way I can describe it. Can`t believe I waited this long to try it.
The photos don`t do it justice. It was getting late in the day and the lighting was not that great. Now to see how well it handles the wonderful New England winter.
View attachment 53414 View attachment 53415 View attachment 53416 View attachment 53417
