Review- DP Total Interior Cleaner
Meghan
Super Moderator
DP Total Interior Cleaner meets light tan interior!!!
Manufacturer Notes:
DP Total Interior Cleaner cleans plastic, vinyl, leather, carpet, and upholstery without harsh solvents or caustic chemicals. The VOC compliant cleaner removes stains and spills from fabric and cleans body oils out of fine leather seats without drying. Clear plastic will wipe clean without any residue. Remove old dressings from plastic and vinyl without depositing any film. DP Total Interior Cleaner contains no gloss agents so it will not alter the appearance of the cleaned surface. Use it as often as needed virtually anywhere in your vehicle. The only exception is glass.
Directions:
  1. Spray solid surfaces, like the dash and console, with DP Total Interior Cleaner and wipe dry with a Cobra Microfiber Towel.
  2. Spray the carpet or upholstery and agitate the surface with a Vinyl & Leather Scrub Brush. Blot dry with a clean towel.
autogeek_2054_64134588
Ok I had a bunch of black marks on the passenger door interior, looks bad when you have light interior!
Used the DP with a microfiber towel to wipe off...
And its all beautiful again!Im the MAN
Here is a good comparison of the before and after...
I will say it again, DP line if the most underrated line out there.... all of the products perform well. I love the banana scent left behind and not harsh chemical smell.
Its just Good Stuff!
32 oz for $15.99
I have both the DP total interior cleaner and the DP interior protectant.
The cleaner works well and the protectant leaves a low gloss finish and an almost matte finish after a wipe down. When they run out I will be ordering more.
Great combo!
I received a sample and have not had a chance to try it. It has an unusual scent but did not think it was banana.
I used it on my daughter's van and those panels were scuffed up by a two year old. :)
I realize we all want to try them all, but I'm completely satisfied with DP.
Can't go wrong with DP, you get a high end product at a price point you can afford to use it on clients vehicles and your own.
+1..I've been impressed with every DP product I've ever tried and these are 2 of my favs!!
