Review - DP Wheel Glaze
grambow
Member
This week I am reviewing DP’s Wheel Glaze (WG). Being the owner of two German vehicles (C350 and X3), I am in a constant head-to-head battle with an overproduction of brake dust. DP promises that WG will not only remove surface contaminants but it will also create a super slick layer of polymers that prevents brake dust from sticking to the wheel. In other words, the answer to my prayers.
Details
WG comes in a generous 8oz tub for $15.99. A little goes a long way so one tub should last a really long time. In fact, I did all 4 wheels on my X3 and only used the product that was on the inside of the cover of the tub.
WG is purple in color and has a grape-ish scent. This was a nice surprise as these types of products can have a “chemically” smell to them. The consistency was a little thinner than I thought it would be. Almost like pudding (instant not the good stove top stuff with the skin like mom used to make ha!).
Goals
Like I said, my main goal was to reduce the amount of brake dust accumulation between weekly washings. I will also be looking for WG to protect my wheels through harsh Wisconsin winters. This is especially important because I can sometimes go for a couple weeks without washing.
My secondary goal was to remove the metallic particles and rail dust that have accumulated on the unprotected wheels to this point (bought the vehicles used).
Technique
I washed the wheels using my normal process. DP Gel Wheel Cleaner (or P21s), Daytona Wheel brush, soft short handle wheel brush, and a bucket of regular car wash specifically for the wheels (for the brushes to soak and rinse). Then I wiped them down with and MF and let them air dry the rest of the way.
I applied the WG with a MF wax pad one wheel at a time. It went on smooth and easy. This mostly due to the pudding like consistency. I let the WG dry and went back to remove the product after all four wheels had been glazed. I removed the WG with a regular MF towel. Removal was also quite easy. I was grateful for this as working on the wheels can be pretty back breaking.
Outcome
Overall I was a little disappointed in the cleaning power. It takes ALOT of elbow grease to thoroughly remove the embedded contaminants. I tried using clay to compare the contaminant removal power and found the WG was slightly more efficient. The wheels had a nice gloss appearance after removal of the WG.
I was also not impressed with WG’s ability to repel brake dust. After one week, my wheels were only slightly less contaminated than before the WG application. However, cleaning the wheels seemed easier with WG protecting them.
Bottom Line
Great value - a little goes a long way.
WG provided a “just waxed” gloss to the wheels on my X3.
Not a miracle product - it takes a lot of elbow grease to remove embedded contaminants.
Ability to repel brake dust was a little disappointing.
I would recommend this product to the person who wants an added layer of protection on their wheels. Especially over the winter months when washed can be less frequent. However, don't expect a miracle product. You sill have to get down there and rub to get the tough stuff off.
Before (but after being washed)
Close up of contamination
Contamination cont.
After
After cont
Weeks worth of brake dust
There are a lot of great DP products that I like but the Wheel Glaze is not one of them. It's much too hard to remove and not very durable. Duragloss 501 is must easier to apply and remove, cleans better, lasts longer and is inexpensive.
Just a little note, you commented on the Glaze cleaning power, although it does clean a bit.. the point of the Glaze is to protect your wheels so the brake dust and road grime does not cling.
I took this to mean it would clean as well.....
DP Wheel Glaze is a cleaner and a polymer sealant that removes contamination from the wheel surface and creates a shiny protective coating. The cleaning agents remove dirt, brake dust, tar, sap, and bugs while improving fine scratches. Wheel Glaze even reaches into microscopic holes created by brake dust to remove it entirely. Neglected wheels will appear clean and clear, like new wheels. Wheel Glaze achieves this finish with wheel-safe cleaners; it contains no abrasives. Your wheels are safe with DP Wheel Glaze.
Great review. Thanks.
I am just curious what tire dressing you used and what product you used on your plastic cladding, looks great.
Also what area in Wi are you in? I am in the Milwaukee suburbs.
I clean my wheels first with a gel wheel cleaner like DP then apply the glaze, it will bond better and is not as strong of a cleaner like DP Gel Wheel Cleaner.
I am in the Fox Valley. The tires have MG Hot Shine spray and I only used MG Gold Class wash (same used on body) for the cladding. Thanks for the compliment!
A question on brake dust accumulation, have you tried wiping the brake dust off, and if so does it reveal the original look/feel of the initial application? I ask this because I use the PBs wheel sealant, It does not repel brake dust, the wheels still do look better than without the sealant (brake dust included), but any dust on the wheel removes with ease and looks clean.
How many coats did you apply? With the PB's I apply at a minimum of 2 coats, it very easy on/off some if the time is available I apply more.
If offers a very light cleaner, but different in formula to Poorboys Sealant. Neither should be used as pure cleaners, more for protection.
Perhaps u misunderstood me, I am not looking for a cleaner, just how easy the wheel clean off with a quick touch up or full wash.
my post above was to let the end users realize the difference in the two formulas. As for cleanup, I have used both and find for several weeks soap/water is all thats needed. I then reapply the sealant after using P21S to clean at monthly installments.
