Black Diamond
- Mar 4, 2007
- 262
Let me start off with saying that is my first use with a foam gun and I am quite impressed.
I used this basically because there was a lot of dust and pollen on my truck from doing yard work today. The truck was not very dirty to start with, but the dust was very noticeable on my black truck.
First Impression: Out of the bottle, this is a thick gel. I mixed it according to directions, 2 oz. DP Xterme to 6-8 oz. of water. When I added the water, the gel remained at the bottom of the measuring cup. I used my fingers to mix the solution. Poured it into the Foam gun container, then shook it up well.
Use of product: Turned on the hose and let her rip! I was amazed at the amount of foam that the gun produced. My black Truck turned completely white! I then rinsed the entire truck and pulled her into the garage for drying. I have to say that I was also impressed when I dried the truck. The surface felt slick and the water came off easily with a waffle weave towel. No streaking. I did notice a couple of water spots starting to form towards the end of the drying process.
Final Impression: I really like this product and it performed as described. It left a nice shine. I just wish that there might be some additional water softeners in the product to prevent any water spots.
Conclusion: I do recommend this product. Try it! You will like it!
