I am stealing this "template" from CEE DOG hope he doesn't mind
Griots Garage Heavy Duty Wheel Cleaner - Initial Product Observations:
1.- Packaging: No exterior packaging.
2.- Contents: (1) 35oz Bottle, 35oz worth of cleaning solution. NOTE: Sprayer is NOT included with the purchase of this item
3.- Clarity of Directions: Clearly printed on rear of bottle.
4.- Consistency: Completely Fluid. Very water like, not a gel like some of the other similar products.
5.- Color: Milky-Clear
6.- Scent: Cherry (not a harsh smell)
7.- Size: 35 fl/oz (also available 1gal.)
8.- Price at time of Review: 16.99 (49.99gal)
9.- Manufacturer: Griots Garage
10-Made in: USA
11-Safe for: ALL Wheel Types
12-Addition items needed: Sprayer, various wheel brushes.
GGHDWC/GGHD - Griots Garage Heavy Duty Wheel Cleaner
SFEWC/SFE - Sonax Full Effect Wheel Cleaner
I am not the best person to write anything. All of this is probably going to be pretty boring and drawn out. I will start with an explanation of what I did with pictures, then go with some after thoughts. There will be a totally separate thread for the people who wanted to read up on the GGHDWC vs SFEWC
My intentions of this review is to give you a view from a beginning consumer level car enthusiast. I am trying to show this product in it's true form, this is why I quickly cleaned a extra dirty rim. I purposefully only brought 2 wheel brushes (I should have just brought the big fender brush). Most people don't have the EZ detail brush, or swissvax wheel brushes or the like. I wanted to show what kinds of results you could expect from an entry level person. Another thing, when I agitated the wheels, I went over them quickly, most of these people do not know the techniques, or how to get a close to perfect rim the first round. I may refer alot to SFE, at this time, this is one of the more popular wheel cleaners in the same category as the GGHDWC.
Product Pictures
When purchased, make sure you add a sprayer, your purchase of the GGHDWC will NOT include a sprayer!
Rear of bottle
Directions/Info Close Up
Front Label/Info Close Up
Sorry I missed some of the action pictures, I did all of the work, and took video and pictures where I could.
Start with your wheel.
Give it a quick rinse with water from a hose. Spray Griots Garage Heave Duty Wheel Cleaner liberally on the wheel (face and barrel)Allow the solution to penetrate brake dust, dirt, and other elements for about 3 minutes.
After the 3 minutes have passed, give the wheels a good scrub (really good on wheels as bad or worse than these). Rinse the wheels.
Repeat if necessary. If done properly, you won't need to repeat. I finish all of my wheels by going over them with quick detailer and a cheap MF towel. This will remove any small amounts of dirt missed during the cleaning step, it will also remove water spots.
Initial thoughts:
I like the wheel cleaner. I have always like cleaners that you let sit for a couple minutes (make sure they are in a shaded area). This initial step helps to remove some of the dirt/brake dust.
Smell: Cherry smell. Unlike SFE GGHD is a very pleasant cherry smell with NO nasty smell behind it.
Ease of Use: Very easy to use, directions printed on the back are easy to follow. I love the fact that this product foams when agitated. Take very little agitation to clean the wheel. Like I mentioned before, this wheel wasn't 100% when I was done, but I also spent about 3 minutes on each wheel, just giving them a quick scrub whit a brush that really wasn't meant to complete the wheel job.
SORRY, WILL FINISH ON MY NEXT BREAK AT WORK
10-Made in: USA
Product Pictures
Rear of bottle
Initial thoughts:
