Review-Guzzler HD Waffle Weave Towel
grambow
Member
This week I thought I would take the opportunity to review one of my favorite detailing tools and perhaps one of the most under reviewed tools on AG, the Cobra Guzzler HD Waffle Weave Drying Towel.
I first purchased the HD Guzzler last fall when I needed to replace a worn regular Guzzler. At first, I was hesitant to spend the extra money on the HD but I could not resist the promise of soaking up twice the amount of water than a regular Guzzler (which is fine tool in its own right). I also thought since it was thicker than the regular Guzzler, I could expect a longer life span.
With the spring purchase of a metallic black Mercedes C350 and metallic blue BMW X3, efforts to wipe the paint as little as possible (to reduce micro-marring) during drying became a top priority. I used the Guzzler HD prior to these vehicles but it was not my primary drying tool. I am ashamed to admit I was a water blade guy. Over the winter I read on the AG forum about the damage the blade can cause and with the purchase of the two new vehicles, I vowed to never touch the blade again.
Details
The Guzzler HD is actually a thin sponge sandwiched between two layers of yellow waffle weave microfiber. The sponge makes the towel four times thicker than the regular Guzzler and SUPER absorbent. It measures 16x24 which is just about the perfect size. Any bigger and it could be more difficult to ring out. The edges are covered in sewn on satin to protect the paint.
Technique
Like I said, I want to wipe/rub the paint as little as possible to reduce marring. For the flat panels (hood, roof, trunk) I lay the Guzzler HD at one end of the panel (up by the cowl for the hood for example), gently pat the towel down to get good contact between the panel and the towel and just pull the towel forward by the front edge. The weight of the towel does the work. There is really no need to apply pressure. One pass is usually enough to get 98% of the water off the panel. Then I work my way across the panel. It usually takes me two or three swipes to make it across the hood. If I lay the towel crossways, I can clear the entire roof of the X3 in two swipes (one on each side).
For the sides, I start at the fender laying the towel against the panel - one hand on top and one hand on the bottom, I guide the towel from front to rear of the car. One swipe will dry the length of a car. I usually go back and get the lower parts of the car when everything else is dry.
Pros
Super absorbent - you can dry most vehicles without ringing out.
Super safe - two layers of waffle weave microfiber between foam....questions?
Pretty durable - I use my Guzzler HD on both vehicles every week and it is still going strong after several washes.
Cons
Not many! This a great tool to have in your arsenal.
Price - This could turn some people off. I think they are worth every penny. But the hobby detailer may have trouble justifying $20 for a towel. Watch for a special (wink).
Size - Not really a con because it is just about right. However, I wouldn’t be crushed if it were a little bigger.
Bottom Line
Buy three! One is great but three would be better. Especially if you are washing more than one vehicle at a time on the weekend. It is always nice to start out with a bone dry towel.
I can’t say enough about how the Cobra HD Waffle Weave Towel has made my life easier. Drying is quicker and the risk of paint damage is reduced because your only have to go over the panel one time. I love it!
Tip
I recently started misting the wet car with DP Rinseless diluted to the QD ratio right before drying. I have found this creates an even more streak free look especially on a black car.
Let me know if you have questions. This review was written from the view of a driveway hobby detailer. I hope to offer some insight to the guy or gal who is not running a professional business and wants the best bang for their buck when it comes to the tools they use to keep their cars and trucks looking their best.
Wet hood after washing
Guzzler HD patted down up by the cowl
Pull from the front - no pressure
Almost completely dry after just one swipe
Roof before
Again - no pressure, just the weight of the towel
Roof after - one swipe
Side technique - from front to rear
After one swipe
After shot with minimal drying thanks to the Guzzler HD
3519427536
Can anyone tell me why my pics are not coming up right? When I made the post, the pictures showed...not just the links.
Why is the roof beading and the hood sheathing. Did you use a flood method from your hose?
I dont really use a flooding method per-se. I usually just rinse with the shower setting on my nozzle. The angle of the hood may have something to do with the sheeting action. Whereas the roof is flatter and alot of the beading you see is on the sunroof.
Not sure what kind of wax is on the car now. I purchased the car about two months ago and the dealer waxed it before delivery. I have been finding wax residue ever since. If I would have known they were going to wax, I would have told them not to.
I have big plans for polish and Fuzion. I have just been waiting for the right weekend for the project. Thinking Memorial weekend.
Of my 20 drying towels (yes, I have to try everything), they are,
without a doubt, the best.
If you're shopping for a drying towel, no need to try everything, like some
of us--start with the best--VIP special is awesome.
Only thing that could possibly top this is a SHAMWOW between two layers oc microfiber--SHAMWOWWOW-- just kidding.
It does dry very well, but I perfer an ultra soft WW. The HD is just too rough for me. It is now collecting dust in my storage closet along with a ton of other stuff like 2 Shmitts.
Good review Grambow! I have the older verison of this towel (without the black border) and after 10 months/several washes it's still going strong. I can dry an average sized car without wringing it out. Then I get out a jr. and do the QD.
Picked up the VIP special on these today... This and a leaf blower should make short work of a drying a car when I'm doing doing a ONR wash.
Very nice review!!! Love all the info and the pictures, thank you.
I love that towel just hate trying to fold it, that foam core makes it a pain to fold. I just stick other towels on top of it to keep it folded nice. I use two to dry my vehicle, one for most of the water and then I follow up for touch up with the other. But I agree, its a great towel.:cheers:
Send me a list. I may be interested in taking some of that stuff off your hands. Possible trades perhaps? There should be a rummage sale section on this forum for us to unload stuff that we purchased but didn't or never use for whatever reason.
Looks to me like all the paint is sheeting, and the glass is beading which is understandable.
Great write-up and really good pics! Helps to have a second hand for the pictures, huh?
Thanks for sharing :)
Leafblower here!!
Nice writeup though. Long ago a golf buddy who paints porsches told me "NO pressure with the towel, basically coast the towel over the paint and air dry.
Leafblower here!!
other than cleaning or polishing, there's really no need to apply much pressure at all when touching paint (waxing, sealing, claying, drying etc). gliding is a good image to use
This review won you $50 Autogeek bucks, please PM me with your info!
I think I bought the wrong one. This is the one I just ordered.
The Supreme Guzzler Waffle Weave Microfiber Drying Towel by Cobra is a medium size drying towel for cars, compact trucks and SUVs.
Will it work as good or should I get the HD???
It will work....but not as good as the HD. I continue to use the Supreme in conjunction with the HD. It usually comes out when I make the final pass. Mirrors, drips, touch up the windows etc. The HD really cuts down on drying time thanks to the absorbency. Hope this helps.
