swanicyouth
- Mar 3, 2011
- 9,388
I've been wanting to "deep clean" my garage floor for a while. I know nothing about concrete. I mentioned it on here and went to Home Depot, and it seemed like the best stuff out there is muriatic acid. So, I decided to learn a little but about it before using it.
First off, this stuff is a dangerous acid. I usually don't worry about gloves, safety glasses, and respirators with stuff like Iron X or Meg's Chrome Wheel Cleaner because I use it so infrequently and I'm just careful. This stuff scared the crap out of me, so I used gloves and safety glasses. If hydrochloric acid splashed in your eyes it can make you blind - permanently. If it gets on skin it will eat it away.
Muriatic acid is just another way of saying hydrochloric acid. Its a highly corrosive strong mineral acid. Interestingly enough, its used in (part of) the process to regenerate the resin for DI water systems, like the resin used in the CR Spotless. The hydrogen ion is used to remove the calcium and sodium that the cation exchange part of the resin (mixed bed) takes out of the water. this is done so the resin can be used again.
It apparently can be used to "etch" concrete or to clean and brighten it depending on dilution. The cleaning dilution is 12 oz a gallon, so that is what I used. When mixing this stuff, you always add water to acid, so if there is any splash back its likely to be just water.
When I was mixing it, a little bit got on the glove. I knew this because even through thick gloves I could feel it warming up. Even after it was diluted, when being applied to the concrete it started to smoke.
The method I used to apply it was to "broom it on" with a nylon bristle shop broom and scrub it into the concrete. Right away you could see the dirt coming out of the concrete. This was dirt that didn't respond to stuff like Simple Green and surfactant based floor cleaners. The floor was already pressure washed with a "turbo" tip.
Interestingly enough, at this concentration it didn't remove stains. While the overall effect is a brighter, whiter, cleaner concrete - most of the stains are still there. I'm guessing a stronger dilution may help, I may try that in the future. What it did do is just improve the overall look of the floor, which pretty much was what I was going after. But, I was disappointed it did little to the stains, which gives the floor an overall "dirty" look.
Here is some before and after pics. Note the black stain as a reference point. It wasn't removed. Also, note the 50/50 area in the after pic where I stopped applying the product. The area behind (dirty area) is how the floor looked before
Before:
After:
You can see in the after pic if you compare the frontal area how the concrete was brightened quite a bit, but the stain remains.
Another "50/50" showing just how bad the floor was:
Here is an after pic of the whole floor. Overall, kind of underwhelming due to the stains remaining. I may try it again at higher concentrations:
If anyone uses this stuff, be careful!
Before:
After:
