The Critic
- Dec 16, 2009
- 673
Iron-X snow soap was designed to be used on coated cars as a maintenance product. Since it has the ability to remove a light amount of industrial fall out, it is more aggressive than your typical car wash soap.
On the two cars that I used it on, the Snow Soap left the paint feeling squeaky clean. After seeing its performance today on a very dirty vehicle, I am certain that this stuff cleans better than Dawn. I also noticed that the paint coating (Opti-Coat) sheeted/beaded significantly better after using this product, so clearly this soap did something to return the coating to a like-new performance.
The application process is a bit different though -- it was never intended to be used in a bucket. One of the recommended methods of use can inflict marks if you are not careful. If the car is extremely dirty, for cost-effective use, you may want to wash with a normal shampoo first, then do a second-wash with Iron-X snow soap. Foaming the car with Iron-X Snow Soap may not be cost-effective.
This was my method of using Iron-X Snow Soap: get a lightly wet wool wash mitt, apply two dime-sized drops, lather up, and wash a panel. Rinse out the mitt in a bucket of clean water after each panel.
The Snow Soap will generate a lot of thick suds, and the suds will cling to the panels for quite a while, even if the car is coated:
In terms of cost-effectiveness, this is how much was left after doing both a Prius and an Altima using the method described above. Prior to this, the bottle was brand-new:
All done!
To recap,
Pros: Awesome cleaning ability, ability to restore paint coatings to a like-new performance level by degreasing and removing light contamination, no added waxes or gloss enhancers
Cons: Odor, cost, slight irritation to skin after prolonged use.
Thanks for reading!
All done!
To recap,
Thanks for reading!
