willtothewong
- Oct 19, 2007
- 261
Hello everyone,
I wanted to share my thoughts and also ask a few questions regarding Meg's D114. I am by no means a professional detailer, just a guy who likes to keep his car clean. Without further ado, here are my thoughts and review on the product.
1.) History: Firstly, I am not stranger to rinseless and waterless washes. Based in California, I am sure many of you know the really bad drought we are having and there has never been a better time for water conservation.
I've used gallons of ONR, DP Rinseless, and just recently, Pinnacle's Rinseless with Carnuba. I've also practice diluting those rinseless washes into their waterless wash ratios and pre-soaking panels before my towels ever touch the paint.
2.) Dilution: I dilute D114 as follows:
Rinseless: 1 oz to 1 gallon for washes that go more than two weeks apart and 1 oz to 2 gallons for washes that are less than two weeks apart.
Waterless pre-soak: I dilute about (and I mean about) 0.25 oz to 1 liter of water.
3.) Method: I use the "several towels in one bucket method" or the Garry Dean Method. I've been using 350 gsm Eurow towels (not super great but it's my DD, so I'm ok with that).
I soak the towels in the solution while I gather all my supplies. Once I do, I spray down the panel I am going to work on liberally; just after the solutions starts to run down the side of the car and onto the ground.
Once that's done, I take my soaking towel and very gently wipe the panel down in straight lines, flip the towel and go back over the same section. I do like how the towel glides over the paint. I then take my drying towel and finish up the panel.
4.) Thoughts: As a rinseless/waterless pre-soak, D114 is a top notch product. It has a great dilution ratio and smells great as well. The cleaning factor is very good too.
I'm sure people have read about the ability for this to be a "panel-wipe" at 1:15 dilution ratio but I have not tested this. I've only used it as a rinsless wash.
One very interesting observation I have noticed after my 10+ uses, the solution "sits flat" on the panels. What I mean is, the solution does not bead, does not fall off the panel relatively quickly. Once I go over the panel with my towel, the left over residue does not drip down or spread; it just stays.
Furthermore, I noticed parts of the panel will dry before I am able to wipe it dry with a towel and to my surprise, no streaks or anything. I am not talking about letting the entire panel dry, but just from the time it takes me to do a few panels and the edges of where I cleaned, the solution "creeps" from it and leaves behind a nice, streak-free surface.
5.) Questions: Now, my question(s) to those who have used this product, is that behavior normal? The residue/solution is easy to clean but I wonder if this behavior is simply due to the contents of the wash.
All the other rinseless washes I've used acted more like water on the surface of the panel but this one does not.
Regardless, this is a fantastic product and I will continue to use it weekly on my vehicles and do not think I will turn towards something else (but I say that a lot and end up trying new things).
Thanks for reading.
Thanks for reading.
