Review: Meguiars Non-Acid Wheel & Tire Cleaner (D-143)
Angus
For this review, I’m going to share my thoughts on using Meg’s Non-Acid Wheel & Tire Cleaner (D-143) as a maintenance wheel cleaner. I’m not going to focus on its ability as a tire cleaner.
*Unbiased Review Disclaimer* I purchased this product with my own $$. This product was not sent to me in exchange for a review.
From AG’s copy:
Meguiars Non-Acid Wheel & Tire Cleaner is a professional-grade wheel and tire cleaner that forgoes caustic acids and instead relies on smart chemistry. Designed to clean clear coated, factory painted and chrome wheels, Meguiars Non-Acid Wheel & Tire Cleaner enables you to save time and maximize profits by relying on one wheel cleaner for most applications. Like the name implies, Meguiars Non-Acid Wheel & Tire Cleaner removes dirt and grime from tires as well. Now that’s what we call a great value!
Over the years I’ve used a lot of different wheel cleaners. You name it - I’ve probably tried it. All in an effort to keep my dust happy BMW rims clean. And as much a Sio2 or SiC coating helps to create a dust barrier allowing for easier maintenance cleaning there are times only using my pressure washer alone isn’t enough. I don’t always need to break out the “big guns” and use a ferrous metal removing product but I still need to use *something* in order to clean my rims w/o resorting to a soapy bucket of wheel cleaning brushes.
Enter Meg’s D-143
Directions:
  1. Spray the wheel or tire down with cool water,
  2. Spray D-143 onto the surface- one tire/wheel at a time,
  3. Wait 30 seconds
  4. Rinse off
  5. Repeat on remaining rims
Here’s one of my rims after a week of driving:
Pre-rinsed with my pressure washer, notice there is still a layer of crud present:
D-143 applied:
Rinsed off after 30 seconds:
Much better! And I didn’t have to scrub anything!!! :cool:
Conclusion
As a maintenance wheel cleaner D-143 when paired with a basic pressure washer like mine (AR Blue 383) is an effective way
of keeping your rims clean. I’ve been using D-143 for the last few months and will be purchasing more.
Will D-143 remove embedded ferrous iron build up? Nope! And it’s not supposed to. You’ll still need to break out a ferrous iron decon product for that, but by using D-143 hopefully, you’ll save time and money by extending the amount of time it takes for ferrous deposits to occur.
D-143 is
incredibly cost-effective @ $21.99 for a GALLON. It can even be diluted 2:1!
Bonus mini review: This was the first time I’ve purchased a Meguiars branded spray bottle to use with D-143. I gotta say it’s a nice touch to use a pre-labeled color-coded bottle so you know at a glance exactly what's in the bottle. I also paired the bottle with a 360 upside down sprayer so no matter what angle I’m holding the bottle D-143 is dispensed.
I hope this review was helpful!
Bonus mini review: This was the first time I’ve purchased a Meguiars branded spray bottle to use with D-143. I gotta say it’s a nice touch to use a pre-labeled color-coded bottle so you know at a glance exactly what's in the bottle. I also paired the bottle with a 360 upside down sprayer so no matter what angle I’m holding the bottle D-143 is dispensed. [/FONT][/COLOR]
[/SIZE]
Good review, Angus.
I like this product for light duty and maintenance. For tougher jobs, I use Poorboy's World Spray N Rinse. (I think it's acid-based).
D143 also represents excellent value. I use it quite often, and ended up picking up a second gallon as I got to about 1/3-empty on my first gallon.
I like the branded bottles, with their color matched labels. Not big on it's size, but I don't have that many to make it an issue. I have, four, I believe. Just enough :)
I need me one of those 360 sprayers. I'm low on my glass cleaner, and i have to hold the bottle a certain way to get the sprayer to pump the stuff out.
Thanks for the review...I'm a wheel brighter user but have looking for something a little lighter...just ordered a gallon thanks again
Sent from my Z982 using Autogeekonline mobile app
Shhhhh, Setec you’re going to get me trouble...
I wasn't trying to get you in trouble, I was trying to look for it in the store here because it sounded interesting, but I couldn't find it.
Fantastic review Angus !!! This wheel cleaner has been on my radar as a supplement to Megs Wheel Brightner. Just looking for a cleaner for maintenance details when clients wheels just need a good cleaning but don't really need or can't use WB. I like the fact that it is a tire cleaner as well.
D143 is my go-to. I haven't found Wheel Brightener to work any better for me, and I prefer the slight foaming of D143. I've always used a brush to help the process though. Never could get away with no agitation to get wheels really clean.
Plus, D143 makes a good tire cleaner. Two birds, one stone, all that. :) I use it with this brush on tires: Low Profile Tire Brush
^ This. ^
It’s my go to as well. I use an old EcoTouch spray bottle which adds a little foaming action. Good stuff and I buy it by the gallon.
I also use it as a tire cleaner. It starts working as soon as the product hits the surface of the tire.
Thanks for the review. :xyxthumbs:
FWIW:
Will this remove an lsp on clearcoated rims??
1.) “Second Law of Thermodynamics”
Or:
2.) I remember that you once asked
a very similar question. Accordingly:
-I know that I’ve always liked, and appre-
ciated, the answer that Mike Phillips gave
to that question. On the other hand:
-I can not state, with the same certainty,
that you had/have the same appreciation.
•[Anyway; and, FWIW; here, again,
is Mike’s response from that time
and place]:
When people ask questions like these
I like to put the question into what all
call extremes, goes like this...
Will using a wheel cleaner add more
was or sealant to your wheel?
If no... what's the opposite of the word add?
My guess is yes, at least a little each time you
use the wheel cleaner. If for no other reason
then via micro-abrasion.
Remember waxes and sealants are sacrificial
barrier coatings, they are supposed to wear off
or sacrifice themselves so the surface they are
on doesn't have to sacrifice itself i.e. were down.
Currently my rims are coated with McK 37’s Hydro Blue and I can’t say I’ve noticed a sharper decline after using D-143 vs just a soapy brush. Given how hot and dirty rims get, from my own observations, LSP’s in general tend to degrade more quickly than another other exterior surface.
I just used d143 for the first time today( I ordered based on this review) and I'm very impressed. I've been using super clean up to now because I'm an idiot and listen to people on YouTube.
I plan on using this mostly for tires because I like megs wheel brightner. My question is would super degreaser trump 143 if used solely as a tire cleaner. I have d101 but never have ordered super degreaser and now I'm curious. Thanks
No, Super Degreaser isn't a very good tire cleaner IME. Especially if you're trying to remove previously applied tire dressings. You should stick with D143 for tires.
If you want a better tire cleaner Optimum Power Clean 3:1 is the best I've found by a long shot.
3D orange degreaser 4:1 is also a great tire cleaner and is actually a little cheaper than D108 Super Degreaser if you're looking for a more economical option.
2:1 works very good. I've used it both ways and didn't notice a difference in performance. 2:1 makes it last longer.
