Bryan@Autogeek
- Jul 16, 2013
- 263
Coat Paint Sealant I decided to give the new formula a try. I wanted to use this product on a darker colored car to test how easy the application was. One of the best things about this product is that you do not After having experience with Detailer’s old formula for the Detailer's Pro Series Poli-need to you a cleaner wax before since it contains built-in bonding agents. These agents will clean and polish the paint eliminating the need for a cleaner wax .Detailer's Pro Series Poli-Coat Paint Sealant will protect your car from UV Rays, road salt, and other road grime. When using Detailer's Pro Series Poli-Coat Paint Sealant it can be applied by hand and give you the results you would get from a machine. When Using applying Detailer's Pro Series Poli-Coat Paint Sealant use thin coats since a little will go a long way. You will notice when applying Detailer's Pro Series Poli-Coat Paint Sealant I used the Gold Wax Finger Pockets to apply the sealant because they are soft and would not harm the paint.
After Applying Detailer's Pro Series Poli-Coat Paint Sealant I noticed an increase in the shine and felt the difference in the slickness. Unlike other paint sealant when using Detailer's Pro Series Poli-Coat Paint Sealant it last for a year or more. When wiping Detailer's Pro Series Poli-Coat Paint Sealant I used the Super Plush Junior Microfiber Towel since it was plush and super soft. This Product was one of the easiest sealants that I have applied. I did not have to go back over the entire vehicle because it did not leave streaks. If you want to keep your vehicle looking new then this is the product to use.
Benefits Of Using Detailer's Pro Series Poli-Coat Paint Sealant
- Paint protection for one year or more.
- Gives paint a wet look and slick feel.
- Can be applied by hand and still get amazing results.
