coopermosley
- Dec 2, 2016
- 32
This will be a review of the P21S wheel cleaner gel.
The P21S wheel cleaner arrived in this box. The box appears to be very professional and well designed.
Product instructions/recommended use:
I used this wheel cleaner on a daily driver that sees anywhere from 250-350 miles per week. This vehicle had been previously washed 3 weeks prior.
As you can see, this wheel had a fair amount of brake dust on it. After exanimating the wheel, I decided to spray on the P21S wheel gel and let it sit for 5 minutes. As the product states that this can be a spray on and wash of cleaner, I decided it would be best If I let the cleaner gel sit and dwell on the surface.
The cleaner did a exceptional job and cleaning the wheel without ANY agitating or scrubbing at all. The gel removed around 80-85% of brake dust and dirt.
Additional view of wheel before treated with P21S wheel gel.
The wheel gel had a harder time cleaning the cracks and crevices, but I would still say that it performed very well.
Overall, I would say that this is a very effective wheel cleaner. The wheel gel did as advertised and removed most of the brake dust and grime. I was very curious if this cleaner had the power to bust through the grime without agitation, and it sure did everything to prove me wrong!
I also used this product on my personal daily driver, which gets thoroughly washed weekly. The wheel gel had no problem removing all of the brake dust off my wheel. No agitation required.
The manufacturer recommends for "heavily soiled wheels" to let the wheel gel sit for a longer period of time (up to two hours) to allow the gel to break down the contamination. they also included a soft sponge to be used to scrub the wheels, but I personally would not feel comfortable using the sponge on dirty wheels as I feel that sponge would not be able to filter heavy contamination or reach hard to clean areas of the wheel.
Overall, I would recommend this product to other people. It has very good cleaning qualities and in conjunction with a couple wheel brushes to clean the cracks and crevices, this wheel gel can be a workhorse!
Thank you, Meghan @ Auto geek for letting me review this product!
REGULAR FORMULA – 1. Insure wheels are cool, if not, coolwith water. 2. Spray fine mist over entire wheel and tires if desired. Nowaiting is required. 3. Rinse with sharp jet of water from hose turned on full.(Use sponge as necessary for heavily soiled wheels.) IMPORTANT! Rinse verythoroughly, especially in crevices, lug holes, etc, until surface feels squeakyto the touch.
GEL FORMULA – 1. Shake before using. 2. Observe all of theabove steps, except: For extremely soiled wheels, allow gel to stand for up totwo hours. Note: Do not allow gel to stand while car is parked in hot sunlight;move to shade or garage.
