Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Review: Pinnacle Black Label Diamond Paint Coating - 2011 Inferno Orange Metallic Corvette Grand Sport
My first article on using a paint coating dates back to 2011, which is also the year of this car. Since then I've used a lot of different coatings in different versions and to date, I would have to say this is my favorite product. Here's why,
1: Easy to use.
2: Creates a super high gloss or glassy finish.
3: Leaves the paint slick and slippery not rubbery like some coatings.
4: Makes washing and drying super fast and easy.
The webpage for this product states it can last up to 3 years and as long as you touch the paint carefully, and by the word touch I mean using a wash mitt, drying towel or any other microfiber towel, to touch the paint, then 3 years is easily in the realm of accuracy. In my opinion and experience, and here's a quote,
Nothing looks as nice as a freshly coated car - Mike Phillips
So while this coating and a lot of other coatings can easily last a long time, the crisp high gloss shine you see like in the pictures below won't hold up for years if the car is a daily driver. That's simply because nothing lasts for ever including you and me, and immediately after wiping off the coating the paint is going to look it's best. So if you want your car's finish to look like it was just coated, then just coat it.
Besides really like the Pinnacle Paint Coating I also really like it's cousins in the PBL line and specifically the Pinnacle Black Label Surface Coating. The PBL Surface Coating is as easy to use as a spray detailer, simply mist a little onto the paint, spread with a microfiber trowel and then flip the towel to a clean, fresh dry side and give that section of paint a final wipe. Please take my word for it, this is the coolest product to maintain at least the PBL paint coating.
The real deal
A good friend of mine recently added another Corvette to his collection, a 2011 Inferno Orange Metallic Corvette Grand Sport with only 16,000 miles on it. Using overhead sunlight I inspected the swirl and scratch level of the paint and it looked great considering it's 8 years old as I type this in the year 2019.
Here's the sun shots....
There's not a lot of swirls and scratches but as most anyone that's detailed a modern Corvette knows from first-hand, real-world experience, the GM Corvette clearcoats are quite hard and after doing 3 Test Spots, in order to remove even this level of light swirling, I had to compound the entire car.
After pictures
And after doing all the steps required to prep the hard Corvette clearcoat here's what Pinnacle Black Label Diamond Paint Coating looks like....
Now this is how a Corvette should look....
Products used
And here's everything I used to take the lightly swirled out Corvette to a swirl-free, show car finish.
Hard Paint
The paint was very hard on the Corvette, which is the norm for most Corvettes from this era. Even though the swirls were light or shallow, I needed to use foam cutting pads and a compound to remove the swirls to my expectations for the finish on this car. If you look at the above picture you'll see Buff and Shine Orange foam cutting pads, Green foam polishing pads and Black foam finishing pads. I tested the green foam polishing pads with the compound hoping this would be aggressive enough to remove the swirls and scratches and while it was good it wasn't good enough so I switched over to the Buff and Shine orange foam cutting pads with the compound and this worked perfect.
Buff and Shine 6" Foam Buffing Pads
This was the first time I used these pads on the new FLEX Cordless CBEAST and they worked really well. The velcro backing perfectly fit the factory backing plate on the CBEAST. Besides that I like the simple, flat face design as this makes cleaning on the fly fast and easy.
Technique Tip
If you look next to the bottle of Pinnacle Black Label Diamond Paint Coating you'll see a simple, yellow foam wax applicator pad. This is what I used to apply the coating. I took some scissors and trimmed the outer edges off the applicator pad as they are not as soft as the face of the foam pad and I didn't want to risk rubbing them against the highly polished paint.
Trimming the edge off a simple foam wax applicator pad
Application thoughts...
This is a very easy coating to apply. Simply mist a little product onto the paint and then a mist onto the face of the applicator pad and spread the coating out over a section of paint about the size of a 16" by 16" microfiber towel. Gently rub the paint until you see the coating for the most part, disappear. Then repeat this until a single panel has been coated. (a panel is a hood, or a door, or a fender, etc.). After applying to a single panel, gently give this panel a soft wipe using a clean, dry INSPECTED microfiber towel. This panel is now coated, move onto the next panel and repeat this process until the entire car is coated and softly wiped to a super high gloss finish.
The secret
The real secret to applying this coating or any coating really is to tackle one panel at a time and slow down and take your time for applying and spreading the coating out. If you take your time you'll do a much better job in all aspects versus trying to rush.
Final thoughts...
If you're new to ceramic paint coatings, the Pinnacle Black Label Diamond Paint Coating is super easy to use and leaves a slick, super glassy finish that makes future washing, drying and maintaining fast and easy. In my opinion, it's a great ceramic paint coating to use if this will be your first time applying a ceramic paint coating.
On Autogeek.net
Pinnacle Advanced Compound 16 ounce
Pinnacle Advanced Finishing Polish
Buff and Shine Orange Foam Cutting Pad - 6 Inch
Buff and Shine Green Foam Polishing Pad - 6 Inch
Buff and Shine Black Foam Finishing Pad - 6 inch
Pinnacle Ultra Poly Clay Kit
BLACKFIRE Paint Prep 32 ounce
1: Easy to use.
The real deal
After pictures
Products used
Hard Paint
Technique Tip
The secret
Final thoughts...
On Autogeek.net
