Review: Pinnacle Xmt#4
HighEndDetail
How would I discribe the new Pinnacle XMT #4 Heavy Duty Swirl Remover
I would start off by saying it is like liquid sand paper. And if you listen to the sound when you unscrew the cap, you can hear the abrasives. It has a peach type color, and smells like a compound. It does it's job and finishes down real well. I chose to use my new EDGE pads. I wanted to see what I was walking into. And went with the white polishing pad first, it worked. But it didn't hit some of the more deeper scratches. So I up'd it to the green edge pad.
Bingo that did it.
I did the hood and left side of with XMT4, working very slowly. Spending a few seconds in one spot at a time. Going back and forth, up and down, and any way else. I was very happy with the results, removed almost all the marks. And killed the water spots on the hood. Did about 95% removal. Working time was great, no drying out of product. I did mist the pad before each panel. I then used PB PwS on the other side of the pad, just to cover my butt. On the hood and left side. Then I had an idea, I mixed 1 part XMT4 and 2 parts PB PwS on the right side of the vehicle. It didn't work as good as the XMT4 alone. But it made that side go faster.
I was very impressed with the new XMT4, and will keep it in my arsenal.
It worked just like the bottle said it would. I did use a little too much product this time. I did 4 chic pea size dots, I will have to use 2-3 dots next time per panel.
I tried the DP Premium Surface Shield
Talk about slickness, on a scale of 1-10 I give it a 10+ on that
It went on easy, and dried quickly. I left it on for about 30-45min. And removed it with the cobra jr. towel. And about an hour later it was so slick, I don't think anything could stick to it.
You can see some scratches and spiderwebbing in the sun
Not as bright,and a little dull
Green EDGE pad it looked new when i started
After XMT4
Now with DP Premium Surface Shield
The cat protecting the goods:D
For killerwheels
More depth from the XMT4 then PB PwS
XMT4 and PB Pws mix
Thanks Ed. Enjoyed your write-up. Truck looks awesome. Is it yours?
Awesome review, really like the way you compared XMT #4 oh and specially on the color.
So one pass of XMT #4 and you got it to LSP ready? I thought that it would leave some scratches but I have used XMT #3 and almost every time I use it I've been able to get it to go straight to a LSP
Now I don't know if it's me but the picture showing the mix dosen't look that good, like I said not sure if it's just me though. oh never mind I just went and read your post again it's not just my eyes seeing things...very nice comparison.
Thank you for sharing, this is what I've been waiting for a very nice review thank you....oh yea nice mug shot hehehe
wow, man, thats a great write up and an awesome outcome. I;m going to HAVE to get a bottle or two of this soon! thanks!
Nice Ed!
Glad you like it.......I knew you would. By the way, that's one helluva write up and pics.
Thanks bro!
I will be tackling a green Tacoma tomorrow with #4.
Looks great!! :applause:
One question, have you used higher end polish or OC? Something lighter on this truck?
I've used far less aggressive polishes and gotten the same result. It looked like maybe some oxidation in the paint. Not sure if you really needed a compound for this one.
To this:
End result:
(EDGE Yellow pad and oxidation)
With DP's SSR and OC. Half-n-half. Took two passes to get it like this.
Not saying I don't agree with the results, they are stunning! But could a less aggressive polish have been used?
I'm curious to use this on a SEVERLY swirled car.
Nice write up and great pics, this was what I was waiting for. :cheers:
Very nice, thanks for taking the time to write the review Ed.
You're up early! Long day ahead?
I've been playing poker online all night, and winning... so I have an excuse :D
Nick19,
I too have used polishes that "have got the job done". It's takes longer or looks different than XMT#4. This new compound will allow me to accomplish my task faster and with the desires results.
Plus, I simply love this line up.
justin30513 said:
Nick19,
I totally agree with that comment. I would rather use something less aggressive, especially just for some light oxidation and light swirl removal. It's not like his truck was COVERED in severe swirls.
We preach the "least aggressive product first" but it seems this is often ignored. I would have saved some clear coat, and taken additional time. But then again, I'm not a volume detailer. If I work on 4 cars a week, I'm happy. (Remember, I'm only 19 and still a FT student)
I hope you don't take this is a way it's not intended to be. Just merely a comment. I am sending a PM your way as well Justin.
-Nick :cheers:
Nice write-up. Looks like XMT4 may be the go to product for tougher jobs. Thanks for taking the time to pass along this information and your thoughts. The truck looks really good.
Nick19,
I took it as a conversation. That is all bro! LOL!
With more experience, one can start out with an aggressive combo and work it until the results are generated. This is done by speed, pressure and time.
This is how we detailers get a tough combo like this to finish down LSP ready with no more polishing.
justin30513 said:
Nick19,
I didn't mean that. I understand that.
I meant why would you use a more aggressive product, when a less aggressive product will get the job done as well.
I'm pretty sure XMT #3 would have cleared up those minor swirls and oxidation just as good as XMT #4.
My point being, I thought we talk about using the LEAST aggressive product first, not most aggressive product.
And I understand going straight to #4 is common (or the most abrasive), and I myself will do it as well. But I almost always will test and see if a lesser aggressive product/pad will get the job done as well.
It's simple.
Time.
I would have to take 5-10 minutes to test on a section. Then wipe off and inspect. This does not include the time it takes to get the product out and set up. Now I have 15-20 minutes invested in a process that might not work. I might have to step up after all. Then I would have to get another product out and start over. Easily 30 minutes of time. When you have 5 to do in a day and it only takes an hour for you to wash/vac a vehicle, you just lost half of that time which to me is 25.00.
I'd rather starte out with the most aggressive setup and learn to work it to save time. Then again, you become an professional estimater with time. You learn to evaluate the paint's condition and select the correct combo for it. Again, all of this comes with experience. You have to do "X" amount of vechicles a day to get this education.
Could Ed have gotten results with a less aggressive combo? I bet yes, but 90% of detailing is taking the plunge and learning. This is why you probably got the PC and stopped doing it by hand. Next will be the rotary. You have to try new things. When you do and the results are better and time is saved, you never look back!
justin30513 said:
It's simple.
Time.
Makes sense. :) I don't detail as many cars as you do, and I'm not on a time limit like yourself. So I guess I took a different approach.
Although your approach makes much more sense if you're doing 5 cars a day like yourself. I might do 5 a week. For some reason it just didn't stick, until now. I see where you're coming from.
Take care Justin, and keep up the good work. :applause:
-Nick :cheers:
-Nick :cheers:
No offense to this but just because he's a full time detailer doesn't mean he's right. I can see the time saving benefits for customers but in this case I agree with Nick. Use the least agressive approach first is a very good idea. I'm no full time detailer but I can look at a car's paint and know what product will get the swrils out. I wouldn't reach for the most agressive polish if I knew something lighter would do the same thing in the same amount of time. Sometime (more than not with customers cars) you need to be agressive but I really don't think using XMT4 'liquid sandpaper' on a vehicle with very light swirls was a good idea.
From the pictures XMT2 or SSR1 would have done the trick in the same amount of time and wouldn't have been as detrimental to the clear coat. Also the end pictures don't have any full sun shots to compare to the befores to see if the swirls are gone of if there is any micromarring left. Anyways good write up and good job AG for sending out the products fast.
If I can jump into this thread and lend a hand on the polish questions....
First everyone is right in their own way -
We should use the less aggressive polish first, and go more aggressive as needed. But if you are a pro and doing this for the money and have the EXPERIENCE to know what and when is the time to go aggressive then you should. We have some guys here that have used many different combos; you find one that works for you and stick with it. Everyone has a different technique, stick with what you know and what works for you. That is the great thing about our forum, we all share our experiences. Enough said!;)
