Review: Poorboys Super Slick & Wax Car Shampoo
CEE DOG
http://www.autogeekonline.net/forum...iew-poorboys-super-slick-wax-car-shampoo.html
Introduction:
This is the second wash and wax I’ve used (both courtesy of Shane). Thank you for the samples Shane! Today I
had a chance to wash a couple cars with it. I used 1 oz. per 2.5 gallons of water which is diluted slightly more than I should have. (I realized this later)
It was a cloudy morning, which was wonderful! I was able to completely finish my Sky and tuck her away in the garage before I got started with the PBSS&W.
Product Description (from AG website):
Poorboys has produced Super Slick & Wax in a limited supply. This car wash is just in time for winter car care when you need to get the most out of every detailing opportunity. A touch of wax has been added to the Super Slick & Suds formula to create a slicker gloss following washing.
Details:
1.- Packaging: N/A
2.- Directions: 1/2 oz. per gallon dilution
3.- Consistency: Thick
4.- Color: Yellow
5.- Scent: Mango or maybe Passion Fruit? I can’t figure it out for sure (Very nice but too subtle for such a great smell)
6.- Size: 16, 32, or 128 oz.
7.- Current Price: $9.99, $15.99, $39.99
8
.- Manufacturer: Poorboy’s World
9.-Made in: Proudly made in the USA
Additional products used for prep, during application, or removal:
1.- (2) buckets with Grit Guards
2.- MF Wash Mitt (Carrand)
3.- Waffle Weave Towel
Method of Preparation, Application, and noted Observations:
After rinsing both cars and washing the wheels on one of them I set up a rinse bucket and a wash bucket. I mixed about 1.7 oz. of product into about 4 gallons of water (slightly less than I should have upon later discovery). Then I mixed the solution together with my arm and dropped the Grit Guard in. Finally, I circulated it a little more with a quick jet of water to activate the suds.
The sun was of no issue so I washed both cars simultaneously. First the roof and windows of each car were washed and rinsed. Next the hoods, trunk lids, and then the verticals were completed. I was curious to see the difference in the sealant by itself compared with after it had been washed with PBSS&W. Therefore I washed half of the hood and half of the lid on the blue car. Then I ran water across them and videotaped it.
Video: Non-Sheeting I
Video: Non-Sheeting II
As you can see the PBSS&W changes the sheeting/beading affect of the lsp. Further testing will be done to prove to that it is not actually removing lsp. I think some will assume that it is. However with a little logical thought I don’t believe that to be the case.
The cars were dried very easily with a waffle weave towel. This was a very good thing since the sun was starting to peak through the clouds. I think I dried both cars in a total of about five minutes! Usually it takes longer so I have to assume the PB SS&W had something to do with the water being entirely absorbed by the towel so much easier. I found this strange since that would appear to contradict the affect it had on sheeting…
While writing this review I contacted Shane and asked him the dilution ratio according to the bottle. He reported it to be 1 oz. per 2 gallons. Since I had diluted my solution more than I should have I mixed up a small batch with the correct dilution to re-tests my feelings on the lubricity and scent. I did not find a difference in either from what I had found with the mix that was used on the vehicles.
Please see the pictures and rejoin me afterwards to see the Pros, Cons, and Summary.
01-Product
02.- Suds
03.- Before
04.- After
05.- Before Green
06.- After Green
07.- After Green
08.- After Green
09.- After Green
10.- After Green
11.- Before Blue
12.- After Blue
13.- After Blue
14.- After Blue
15.- After Blue
16.- After Blue
Pros:
1.- Cleans very good
2.- Seemed to add gloss
Cons:
1.- I’ve seen better lubricity
2.- Slows down the sheeting action of applied water
1.- Changes the Sheeting/beading affect of the LSP (This is most likely a temporary affect) Its supposed to rain the next 2 days and that should give us some more insight.
2.- Rich creamy suds in the bucket but they don’t seem to last long or transfer to mitt
Final Observations and Summary:
I prefer this Wash & Wax to the Meguiars Ultimate Wash and Wax mainly due to these three factors:
Perceived superior cleaning ability
Overall look of the vehicles after being washed with it
Ease of drying the vehicles
However I didn’t like the effect it had on the sheeting/beading of the LSP that was on the blue car. Some might assume that it stripped the sealant but I don’t believe that to be the case. I believe that what "wax" this product leaves behind is what causes a difference in the surface tension. I will report back after doing some further testing with a stripped and freshly waxed 50/50 test panel. I also felt the lubricity left something to be desired. Personally I prefer a dedicated wash to a wash & wax however I enjoyed using this product more than I expected too. The scent is far too subtle for such a fine aroma.
And the Product Link:
http://www.autogeek.net/poorboys-super-slick-wax-32.html
Thank you very much for the review Corey! :dblthumb2: I too do not use wash and wax products much, but I did get these two (PB SS&W and Meg's UW&W) to try out. Let me know if you need more SS&W for further testing.
2nd Impression:
When I got up this morning for work it was and had been raining. The cars were covered with some good beading. I was very impressed. After what I saw this morning I like this product. Will keep watching for the next day or two...
I want to add: it seems that this product does exactly what it is advertised to do. Adds a little protection without any added effort. :dblthumb2:
Good idea to put quick disconnect on short piece of hose for flooding water
Products come and go, they change, and their formulation changes from time to time. This is just another example of why I like trying new products.
Great review Corey! :props:
Corey, nice review....also the clouds are getting better too !
Great review Corey. Thanks for taking the time to put this together. :props:
THank you Doug. I wish I could remember who to give credit to for this idea...
Great write up Corey! :xyxthumbs:
Thank you Pockets!
Thank you Bobby!
Thanks Al! As far as the clouds go ... :laughing:
Thank you, it was my pleasure
Corey - have you reviewed the Meg's Shampoo+ and the DG 901?
Thanks for the review.
DLB
Nice review. Very thorough. I go back and forth on W&W products. Your review helps.
Thanks for the great review. I love those after shots! One question, now be honest, did you paint the clouds on or what???!!!
