StephenK
- Jul 23, 2006
- 1,589
well finally getting some nice weather so i decided to try out the Sonus Rim Bright Wheel Cleaner that i had won in the "loser giveaway"
well i went to a coin operated wash since they have high pressure guns and i do not have a pressure washer.
BEFORE
AFTER SPRAYING WHEELS WITH HIGH PRESSURE RINSE(can still see alot of crude on wheels)
AFTER USING SONUS CLEANER AND WHEEL BRUSH
the product came out in a fine wide mist. it did have a chemical smell to it but it was not a strong smell. i let it dwell on the each wheel for about 30 seconds then agitated with wheel brush and sprayed with high pressure. from what i can tell it worked just as well as the S100 wheel cleaner. the rims are trashed so i know they are not perfectly clean plus trying to let it dwell long enough to attack the dirt and beat the timer at the wash i missed around the lip in some spots and in the corners. if it was not for the fact that i could pick up S100 locally this would be my good to wheel cleaner.
sorry this review is not as detailed as some but i have not been gifted with the gift of being able to explain in detailed how something works but i do hope this may help some
BEFORE
