Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Review: Speedmaster Vac-n-Blo Jr.
From the website
Speed Master Vac N' Blo Jr. Hand-Held Vacuum
Easily clean even the smallest crevice!
The Speed Master Vac N' Blo Jr. Hand-Held Vacuum makes cleaning your interior an absolute breeze! This hand-held machine can be used to either quickly vacuum away all the dust and dirt that collects on your seats and dash or expertly blow every speck of debris out of the niche crannies between the seat cushions. The Speed Master Vac N' Blo Jr. weighs less than 3 pounds, making it easy to deftly maneuver around your interior while you are cleaning!
Nobody likes to spend money on purchasing a new tool simply to have to replace a year or two later due to wear and tear. To make sur that you are definitely able to get your fair share of use out of the Speed Master Vac N' Blo Jr., it was designed with extended durability in mind. The sturdy steel construction of the Speed Master Vac N' Blo Jr. means that you will likely have to replace the upholstery on your seats before you have to worry about replacing your Speed Master Vac N' Blo Jr.
The amount of power that is packed into this small, light-weight machine is certainly surprising! The Speed Master Vac N' Blo Jr. boasts an impressive .75 horse power motor than gives you enough suction or blowing potential to tackle any mess you may run into with your interior. This motor allows the Speed Master Vac N' Blo Jr. to move air at an outstanding 70 cubic feet per minute! That is quite a lot of air for such a tiny appliance!
The various attachments and accessories that come with the Speed Master Vac N' Blo Jr. really allow you to hone all that power for any cleaning situation that you may come across. The Crevice Tool fits easily between seat cushions and even into the space between your seats and your center console.
The Dust Brush helps to lift the fibers of your carpet and upholstery to release the ground-in dirt, promoting a better clean.
With the Air Inflator Nozzle, you will be able to focus the air flow tremendously, so you can get intense blowing action into even the smallest nook!
Whether you are detailing car professionally or just trying to make sure your own garage queen always looks its best, the Speed Master Vac N' Blo Jr. will give you all the power and potential you need to do so!
Technical Specifications
Accessories
Technical data read fine, so let's take a look at what's in the box?
Opening the box...
Here's everything that comes in the box...
List of extensions and attatchments
In the back is the 20" Extension Wand
In front of the extension wand is the 18" Flexible Extension Hose
Out in front, from left to right are,
The Dust Brush, the Carpet and Floor attachment, the Magic-Air Inflator Nozzle and the Crevice Tool
In the back to the left are 5 replacement vacuum bags. The actual vacuum is just to the right and in front of the vacuum is the 12' electrical cord and the shoulder strap is in front of the cord.
Here I've stretched out the cord to give you an idea how long it is...
On the front of the vacuum is a lid that can be removed or replaced by simply twisting it clockwise or counter clockwise...
Here's a replaceable vacuum bag....
You install by simply inserting the back into the opening of the vacuum body...
Just inside the opening of the vacuum lid is a rubber diaphragm that flexes to let dirt in when the vacuum is turned on.
Here's the rubber vacuum from the inside of the lid, you can see how I've poked an ink pen through it to show you how it opens. It closes to keep dirt from getting out when the vacuum is turned off.
On Autogeek.com
Speed Master Vac N' Blo Jr. Hand-Held Vacuum - $129.99
From the website
- Construction: Sturdy All-Steel
- Motor: .75 Peak HP
- Amps: 4.5 Amps
- Watts: 500 Watts
- Airflow CFM/FPM: 70 CFM
- Cord: 12 ft. 2-Conductor cord
- Dimensions: 16.5"x4"x5.5"
- Weight: 2.7 lbs
Accessories
- Upholstery Tool
- Crevice Tool
- Magic- Air Inflator Nozzle
- 20" Extension Wand
- 18" Flexible Extension Hose
- Shoulder Strap
Opening the box...
On Autogeek.com
