Review: The Autogeek Cover-up Towel by Mike Phillips
The Autogeek Cover-up Towels
The Autogeek Cover-up Towel is a soft washable and re-usable microfiber towel that is 25" x 68" so it's perfect for covering up areas of a car or other detailing project where you want to protect the surface from any type of sling or platter.
I use these all the time for various areas of a project that I don't want to get compound, polish or splatter dots on when machine buffing. They save you a TON of time from having to go back at the end of the project, (at the end of the day when you're tired), and use a toothbrush to try to remove all the little annoying splatter dots.
Here's how you use them...
I use a few pieces of tape to secure the towels in place...
Ready for some fast and furious machine buffing....
Compound Splatter Dots
Here's an example of what you're preventing from getting on the engine, blower or whatever it is you cover-up...See the compound splatter?
Lets get a little closer.... now see what a mess you can make to unprotected areas?. Can you imagine this type of spatter all over the blower or carburetors of this streetrod and what a pain it would be to spend hours removing it?
Saves you time
The Autogeek Cover-up Towels save you time by shielding areas from machine sling and splatter so at the end of the detailing job you don't have to come back with a toothbrush or utility towel and spend hours cleaning up.
Projects a professional image
The Autogeek Cover-up Towels create an impression of professionalism to your customers showing you're smart enough to protect areas of their car from splatter and that you both care and take your profession seriously. Kind of like a mechanic's Fender Cover that a professional mechanic places over the fender of a car when doing repair and maintenance work to protect the paint on the car from damage.
Eco-friendly
They are washable so you can use them over and over again.
The Autogeek Cover-up Towels are time savers and this helps you to maximize profits while projecting a professional image.
On Autogeek.com
Autogeek Detailing Cover-Up Towel
All RUPES Tools, Pads & Products
SCANGRIP Sunmatch Swirl Finder Light
How to use the RUPES BigFoot Paint Polishing System
Blown 1936 Ford Pickup Street Rod - Sorry, currently out of stock...
Mike
Great write up, I have 2 of the cover up towels when they first came out, they are time savers, and look great when you take pictures of a customer's car as you detail it and when they ask about it, I tell them part small touches to keep their perfect before delivery
Mike
57731d1496752510-review-autogeek-cover-up-towel-mike-phillips-img0554jpg
Thanks for sharing!
The newest version is the bright artic white like I show in the pictures.
Whatever the color, they are time savers and do add professionalism to our work.
