sweatthedetails
Member
- May 15, 2012
- 483
This is an outside the box product by a company who has excelled with such. But unfortunately I think it’s missed its mark.
Let me start by stating my primary purpose for purchasing this kit. I’m a detailer who owns an extractor and a steamer, so my main hope for this equipment was to remove sand from cars. Currently my best method is to use the Tornador blow out gun, moving it in unison with my vacuum in an attempt to catch as much debris as possible. Of course this results in a large dust cloud that settles all over the vehicle.
So I buy the kit and hook it all up to my Black, first thing I notice is the size of this set-up. There is no way this is going to be convenient to use inside a car. It’s bulky and awkward to maneuver.
So I fire up the vacuum and I notice right off that the velocity part is more than marketing. You can check the suction with your hand. From the vacuum hose then hook it up to the tube it’s a huge difference. I’m not a scientist but I guess it has something to do with the opening going from small to the large mouth opening on the front. So great I think this should really pick up the moisture. But you would be wrong to think this. Think about any extractor you have ever used, typically a small but powerful opening. This concentrated suction is what you want to suck out moisture. I used the machine on my mats and my seats, the first thing I noticed is just how wet they are. Yes I did do several drying strokes over the area like the videos instruct. So I start by looking inside my Ridged wet/dry vac, it was completely dry. So I opened up the hoses, a little moisture but I think it is more from the mist then sucking anything up. So now I have a wet interior which is no more clean then just running the Black over it. FAIL
Ok, I think that I was not planning to use this as a shampooer anyway. So I pick out a dirty spot on my floor board and go to work, full suction and blasting the trigger on the Black. It seems to be doing ok, so I grab my blow out gun and run it over the area just to be pelted with all the sand still in the carpet. Out of curiosity I put my hand in front of the inlet and squeeze the trigger, it feels like a pretty powerful blast from the Tornador. Then I turn on the vacuum and do the same thing, that blast barely tickles my hand. The vacuums suction is diminishing the Tornadors effectiveness. So as a dry vacuum it’s useless. FAIL
At this point I’m thinking of cutting my loses, maybe try to sell this thing to get part of my $70 back. It’s been about 4 days since I last used it. I needed my Tornador for an upcoming detail; so I remove all the useless plastic on it which is the Velocity Vac. I hook up the air to my Black, squeeze the trigger and the air comes out the opening but it’s not rotating. I take off the black shroud and twist the rotational set by hand. It feels stiff and dare I say a little gritty. I know the bearings are advertised as closed but I don’t think this machine was designed with the idea of the amount of debris it would encounter in a vacuuming modification. Now my bearings are shot and I need a replacement rotational set. FAIL
So in conclusion: instead of a new $70 tool I get to pay a total of $140 just to be back where is started!
FAIL FAIL FAIL
This is one tool I believe Tornador should recall in order to keep their loyal client base.
FAIL FAIL FAIL
