Bryan@Autogeek
- Jul 16, 2013
- 263
As many of you know i purchased a Subaru BRZ and it has been a blast to drive. Since I am starting to getting the mod bug I wanted something that would be easy to do so I decided the dealer got enough free advertisement from me and decided to replace the dealer frame for a Weathertech ClearCover License Plate Frame. After I a Weathertech ClearCover License Plate Frame I took a look at everything that was included and was very impressed it included Stainless Steel hardware that would be able to fit most vehicles. It is always good to have a friend help out to catch pieces that you do not want to scratch or lose. The Weathertech ClearCover License Plate Frame will protect the License Plate from getting bent, Bugs, and any kind of chips. You can choose from six different Frame colors I decided to go with the chrome since i figured it would look the best against the WRB (World Rally Blue) Paint. The Weathertech ClearCover License Plate Frame is made out Eastman Durastar Polymer which means it will not yellow over time,crack, or dull so it is virtually indestructible.The gasket seals that are used will keep the moisture out it also has a stepped lip so the license plate fits nice and snug. After the plate was installed i decided to give it a quick wipedown using the the Marine 31 Plastic Clear to remove any fingerprints that were from the installation.
With the Gasket going around the whole frame you do not need to worry about moisture getting in.
Having an extra set of hands helps to ensure you do not loose the Screw Covers and prevents them from being scratched.
This Stainless Steel hardware that would be able to fit most vehicles.
I laid out all the screws out to see which one was the closet match
The screw covers just snap back in.
I used the Marine 31 Plastic Clear to remove any finger prints that was on the plastic.
Look much better!:xyxthumbs:
WeatherTech ClearFrame License Plate
