Review: Wolf’s Chemicals Nano Textile Sealant
Bryan@Autogeek
Since my 2008 Chevy cobalt has cloth interior I decided I needed a product that would protect it from spills and getting dirty. After looking at a couple of coating's for cloth interior's I went with Wolf’s Chemicals Nano Textile Sealant. Before applying the coating you want to make sure your seats are completely clean so the coating can bond properly. Once the seat is completely dry you it is time to spray the seats with Wolf’s Chemicals Nano Textile Sealant. When spraying Wolf’s Chemicals Nano Textile Sealant onto the seat make sure you hold the bottle about 10cm from the seat.
Once the seat was sprayed with Wolf’s Chemicals Nano Textile Sealant I waited 20 minutes before it was dry. After the seat was dry it was time to apply my second coating to ensure I had even coverage. For the product to fully cure it takes 12 hours but since I did not have 12 hours to wait so I waited two hours to test Wolf’s Chemicals Nano Textile Sealant. When I poured water onto the seat I was not expecting it to shed water the way it did. If you do not cover a certain spot you will see the water get absorbed instantly by the fabric.
My overall opinion on the product is that it was pretty amazing the way it shed water. If you want to protect your fabric seats from accidental spills then this is the product to use. When spraying Wolf’s Chemicals Nano Textile Sealant onto the seat the bottle fit in my hand so it was not uncomfortable when spraying.
Bryan, could you comment on the smell? I've read elsewhere that this product smells pretty bad when applying but it goes away. What were your thoughts on the smell?
Bryan,
Do you have an update on this? And what about the smell question? Good, bad, tolerable?
Thanks
Bryan,
Thanks
I Will try an get an update over the weekend as I no longer drive the car and it is in storage. When using the Wolf’s Chemicals Nano Textile Sealant I noticed it did not have a particular smell.
