REVIEW: Wolfgang Uber All-in-One on a Dark Blue Mercedes Benz CLS550
jarred767
Hey everyone! So I was lucky enough to get chosen to receive and review a couple of new products. Thanks again Nick!!:xyxthumbs: Here's my first review on the Uber AIO:
watermark.php
Opened it up and found it's a very light greeny blue color, quite thin (almost runny) and smelled quite nice. I had a tough time pinpointing the smell, but it was enjoyable to work with for sure (my customer even mentioned how his garage smelled so good while I was buffing) :props:
So here's the car I decided to test it out on, sorry not the greatest light for pictures in his garage:
watermark.php
watermark.php
watermark.php
The paint seemed like it was in pretty good condition considering it was only two years old, and in the above pictures (after a rinseless wash and decontamination using a Nanoskin sponge) it looked pretty good. Some close-ups with the Brinkman proved otherwise though:
Hood:
watermark.php
watermark.php
Passenger door:
watermark.php
Trunk:
watermark.php
I'll spare you all the pictures, you get the point, it wasn't in terrible condition, but had most likely been through some tunnel car washes or simply not taken care in all the right ways and needed a little bit of love. Enter Wolfgang Uber All-in-One:props:
I've read a lot and knew that I could use a wide range of pads and tools with this product based off of what I was wanting out of it, but I decided to use a pretty basic setup. My customer was only wanting a simple wash, decontaminate, and 1-step, so I wasn't looking to make drastic improvements in swirl marks (there has to be some sort of incentive for them to get a higher package, right?) :buffing: With that said, I decided to use my Meguiars G110 DA with a 5" orange Lake Country flat pad. I probably could have gotten even more cut had I used a MF pad and/or my Rupes, but my idea of an AIO is one that I have to worry about as little as possible and get the job done right without being fussy and causing issues - again, leave a reason for the customer to get something a little more in-depth, plus I'm usually on some sort of time schedule with simple 1-step jobs. If you wanted to though, you could probably get even better scratch removal results with a more aggressive pad/machine combo.
Back to my experience... So, I didn't think to take pictures of actual process of using the Uber, sorry about that, but I did a test spot, (without letting it haze) and was very happy with the results - especially for an All-in-One - so I went ahead and started going to town on the car. Like I stated earlier, it was fairly thin and went on quite easily. On a side note, one downside to the thinness of the product was it was a little messy coming out of the bottle so ended up wasting a small amount of product:
watermark.php
Very easy to spread the product though and it had a pretty long buffing time; I was able to easily do a few passes without it drying out at all. There was absolute zero dusting that I experienced, so that was an absolute non-issue for me. The cut was very good for an All-in-One and it didn't seem to lose anything in final finish ability to have that much cut.
After doing the hood and then roof, I went back to check on the hood to see if it was ready to be wiped off (I usually use Meguiars M66 for my basic 1-step jobs and I can easily do the whole car and then go back and start wiping off, but I figured I'd check earlier just to make sure) and got nothing from the finger swipe test, it was a little odd. It didn't wipe clean, nor did it smear, so I tried wiping it off with a MF towel and almost nothing came off. Up until this point I had been extremely happy with the product, but things quickly changed. I had to go back over the hood one section at a time with some fresh Uber and try and buff off the old wax and it still didn't finish off that great. So I then had to dampen a MF with some Meguiars D156 spray wax which helped it clean up and then I got to see the true final results. I've had similar issues with Meguiars D151 in the past, and the D156 has helped, so that's why I tried that out, just an FYI. By the time I had finally gotten the hood cleaned up and got all of that dried wax off, I had the same issue on the roof of the car. I got that taken care of the same way and then decided that I had to have a new plan as I had already spent way more time on the hood and roof than I normally would on an entire car for a 1-step. I will say that temps were lower than ideal when I was applying the wax as it probably topped out at about 40 in the garage, so that could have been a factor in the difficult removal.
Once I got back to applying the Uber I did two sections, then wiped of the first, then just rotated all the way between applying and removing so that the wax didn't sit too long on the car (maybe 5-7 minutes) I still needed to use the MF dampened with D156 followed by a dry clean MF, but it was the only way to get all the wax off. Again the temps could have been affecting the removal process.
Here's some close up after shots of the paint after the process was complete:
watermark.php
watermark.php
watermark.php
Here's a few 50/50 shots I took as well:
watermark.php
watermark.php
watermark.php
Not 100% correction, but for a 1-step cleaner/polish/sealant with a basic DA and orange pad, I would say I was very impressed with the correcting ability to say the least. The final finished product was also very impressive, it finished off quite nicely and left an amazing amount of depth and gloss for a 1-step (Disclaimer: I can't guarantee the D156 didn't aid in this, but I had literally no other way to get the wax off the car, so I had no choice). Here's some more pictures once I finished everything off and pulled it out of the garage.
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
The customer was extremely pleased with the final results and couldn't wait to tell his friends about the car and how it was once again like it was when he bought it.
My final observations were that it was great product and did exactly what it was supposed to. Cut very well, finished extremely well and was easy to use minus the wiping off. Because of how thin it was, I used a very small amount of product, maybe 1 - 1.5 oz for the entire car; after priming the pad, it only needed a couple pea sized drops per section. It was also very easy to clean from the pad when cleaning on the fly; it didn't gum up the pad at all.
I want to give it another shot once it gets a little warmer here (it's been colder than average this last week) and I will be sure to update this then and let you guys know if it was a one time thing with the wipe off and cold temps. Great product though, and one that I will seriously consider replacing D151 as my more aggressive AIO if I get good results in warmer temps.
Thanks again for the sample Nick! It was fun to try out a brand new product and share my thoughts.
P.S. I should have a car in the next week or so to try out the Pinnacle Compound on and review it as well.
Car looks great. Nice review. Nick commented on someone else's review that you actually need to use an "ample" amount of product instead of following the less is more rule and that it was fine to wipe the product off immediately.
Hmm, good to know, I never felt like I needed more product, unless that for some reason helps with the wiping off.
It says right on the bottle that you're supposed to let it dry to a haze, that's interesting and I must have missed that part as well, or maybe it dries to a haze immediately... Either way good to know and I'll try out some different techniques with the next car and update further!
Awesome review!! I bought a bottle based on Wolfgang's Reputation. Based on your review it looks like I did the right thing!!
I will be toying with some of the technique's on the product (hazing, drying, amount of product, etc) as well as Pads (Orange Pad, White Pad, etc) to see if I can master the product without going to a 2-Step.
Again, AWESOME review!!
Great job! I experienced the same difficulty removing the leftover product. Nick says that you can wipe it almost immediately after polishing, so that's how I'm using the product now. After every work section, I wipe off within 30 seconds.
And this doesn't affect the protection or durability at all? If so, then this is probably the way to go as other than the wipe-off, it was a joy to work with and the results were amazing.
It shouldn't according to the steps that Nick listed here
"1. Ensure an ample amount of product is applied
2. Don't work the product too long - 4-5 passes is all it takes
3. Wipe the product off within 30 seconds of applying it - this is all the time it takes to "dry to a haze." You can eliminate the "drying to a haze" step completely if you can't get the hang of it. This will hardly impact the durability."
It really is a great product once you get used to it.
Did that MB have the ceramic clear?
Thanks for the feedback, I had read that thread earlier, not sure why that didn't stick (I sure wish it had on Saturday afternoon).
I'll try and dial it down the next time I use it and post an update, but that is most likely the reason I was having difficulty with it. Good to know that it's just a simple technique thing and not the product because everything other than that with this Uber was fantastic.
Now if only the price was a little more in line with what I charge for an All-in-One job....
Thanks for reading, and great question. To be honest, I was unsure what you meant by ceramic clear, so I did a little Google search (which brought me right back to AG BTW) and :eek::eek::eek:
So, after reading a huge long thread started by Mike Phillips on Ceramic Clear Coats used by MB and other high end car manufacturers, I have no idea if the MB had a ceramic clear, but my guess is the AIO probably wasn't aggressive enough to break through that harder top layer (just a guess though). I didn't notice any weirdness in the paint once I finally got the wax off, so either it didn't break through or it just had a regular clear.
Thanks for pointing it out though, as there was a ton of great info in that thread that I never knew about and will be extremely beneficial to know when working on MB's in the future.
For those interested, here's that thread of Ceramic Clear Coats: http://www.autogeekonline.net/forum...estions/47152-ceramiclear-paints-careful.html
Excellent review!
In addition to these tips, I would also include:
Nick@Autogeek said:
We all get caught up in the saying "less is more" so most people only apply 2 or 3 "pea sized" drops. While this might make sense for a finishing wax or sealant, it doesn't pertain to an AIO or cleaner wax. An ample amount of product is required so the cleaners in the AIO can effectively remove any embedded dirt and grime.
If I had to make an educated guess, 3-4 oz. of product would be considered an "ample amount" for a vehicle the size of the CLS.
Keep us updated on the durability if you can! :dblthumb2:
