Mike, I have a restored 1969 Buick GS400 convertible.
You actually used it to film a couple of commercials. My question: is there a way to clean and protect my convertible top without having to rinse the car with a hose? I don't want to flood the car with a hose and have water collect in areas I can't get to so I always use a rinseless wash. I'd like to use a similar technique for the top.
Thanks,
Jack.
Hi Jack, last year I cleaned and protected a vinyl convertible top without running water.
I show how I did it here,
Review: Machine applying RaggTopp Vinyl Cleaner and Protectant - 1967 Camaro Convertible
I showed machine cleaning with a tool that cost around $450.00 and a DA Carpet brush by you can work by hand with a good brush.
then before the cleaner dried I wiped the area I cleaned with clean towels.
Here's the section that talks about this in the above article
Step 3: Using a clean towel, wipe off all the dirt and grime the cleaner loosened.
You can also rinse the top by flushing with water but because I was doing this work inside I started by wiping the grime off and after two thorough machine cleanings,
I then used a rinseless wash to fully rinse and wash the top off.
To RINSE all the vinyl cleaner off, I then washed the top via the "Rinseless Wash" technique but instead of using a real rinseless wash (they all contain "stuff" I don't want on the top), I used SONAX Glass Cleaner.
And guess what... I have an article on this topic,
SONAX Glass Cleaner as a Prep Wash
I put about 3-4 gallons of of water in a bucket and then poured in about 4-5 ounces of glass cleaner.
Then I take my stirring stick and mix the water and glass cleaner thoroughly.
Then dunk about a dozen clean, inspected towels into the solution.
The above pictures are from doing a rinseless wash on an old Dodge.
BUT - I used this same technique - just less towels to WASH the top on the Camaro. Wash with one wet towel and then dry that section with a clean dry towel. Not as good as running water but damn close.
Hope this helps...
