Kinalyx
- Sep 23, 2011
- 338
Curious about everyone elses rinseless wash method.
I dont remember where i found this 1, but its a variation of the Gary Dean method, but you keep using the same rinseless wash water and bucket.
Basically i mix the rinseless wash, add my grit guard and put 20ish, folded, microfibers into the bucket.
When ready to wash i need a few dry microfibers for buffing/drying. I pull the first towel out of the bucket and wring as much out as possible until its only damp.
I pull a second microfiber out and wring a bit out but leave enough to do the wash of the panels.
The wet towel is for cleaning, the damp is to "dry" the panel, and the dry is to buff/final dry of the panel. When the drying MF gets too damp, grab another.
After each MF is fully used it gets put aside in a dry bucket or bag, after the wash they get washed and dried and put back into the bucket for the next wash. I am usually able to get 5+ washes from the same bucket of water without adding any additional water or wash solution.
I find this to be the most efficient way to do a rinseless wash i have used.
SIDE NOTE: Since the water is being used for more than 1 wash, i only use distilled water for this process.
Shawn
Shawn
