I'm new to DIY detailing. I got a new car a couple months ago. I put a base coat of Turtle Wax Hybrid Solutions Graphene Infused Flex on it right away, and have washed it a few times since, using chemicals, tools, and techniques I picked up in this and other forums, and in youtube videos. I was using water from my outside spigot which measures 135 on a TDS meter. At the end of each of those washes, I towel dried it. All was well. Paint was slick and shiny, and few if any water spots.
I just got a Griot's Garage De-ionizer this week. I verified that it can reduce my TDS reading to zero.
I did my first wash this evening with the de-ionizer included in the process. At the end of the process, my car was covered with a blotchy white-ish film, both paint and glass. It was very hard to remove - a lot of elbow grease and Invisible Glass on the windows, and a detail spray on the paint. As I was using microfiber cloths in the film removal, there was a lot of drag on the cloth until I got most of it removed from a panel, then it was a little slicker. I ran out of daylight before I could finish removing all of it. Only got about 20% done.
Wondering what I did wrong. My steps were:
1. Pressure rinse the car with hard water (i.e. the 135 TDS water)
2. Foam it with a pressure washer foam cannon and Adam's Mega Foam, using hard water
3. Contact wash
4. Pressure rinse well with de-ionized water from the Griot's unit.
5. Then a step I hadn't done before in previous washes: To top off the TW Flex base coat, I sprayed more Flex on the panels while it was wet from the de-ionized water rinse, then rinsed it again with de-ionized water to spread the Flex out. The instructions say you can do that, but it does say to towel dry after doing it. But I figured with the de-ionized water, I didn't need to towel dry it.
When done, I saw the blotchy film. I wondering if using the Flex without towel drying it could cause the film. Or perhaps I let the soap dry on the car while I was contact washing it (it was 88 degrees out and the soap was drying quickly.)
Anyone have an idea of the cause of the film? And what do I do now to get the rest of the film off. Would washing it again (without the TW Flex step) remove it?
Thanks.
3. Contact wash
Thanks.
