The reason this thread never got any answers is because there are different variables involved on each job and with each rotary that pretty much make it a per vehicle, per panel, per paint system, per paint color, per paint manufacturer, per machine, per detailer technique answer.
Read Mike Phillips' articles about doing test sections and you'll have a better idea why this question really can't be answered other than to say that depending on all of the above mentioned variables "anywhere between speed 1 and speed 6".
On hard clear coat systems you can crank the speed up pretty high, whereas on a really soft paint system that same high speed might burn the paint. You really need to take each job on a "least aggressive method" basis. Only when you've done your initial test section(s), will you have a good idea of what speed to be running at, then you work your way back the rear quarter and get to the curve around the wheel well or rear bumper and you'll be changing speeds again.
There's a certain element of risk that a new rotary user has to take "a leap of faith" on, coupled with some good book smarts and video information to begin using a rotary. This is why it's often suggested to start practicing on a panel from a salvage yard or an old beater car that no one cares about rather than a customer's car or your own pride and joy.
