sneek said:If not 3000RPM what would you say is a good speed range?
Sevenrd said:I've never used that high an RPM, nor would I ever consider doing so. Too much heat generated too quickly. Great way to burn the paint/CC.
I'm usually in the 1100 - 1500 range. The highest I've gone is maybe around 1800 on some stubborn swirls.
:iagree:Nica said:3000 rpm wow that's crazy...I agree with Al. Maximum that I've used the rotary is 1500 rpm and that felt good, it felt just right. I agree though there are some compund that require heat to break down properly, that's when you may need to go to 1800 to 2000 rpm.
