Todd@RUPES
- Dec 23, 2007
- 409
I am sitting on an airplane so I cannot go into too much detail, but your polishing time per section is about 4 minutes too long. After 1 minute you are loading paint residue into the pad, the abrasives are loaded with paint, and the lubricant is no longer as effective.
The combination of a lubricant that has lost efficiency and a slurry that has more solid content mean your results are going to suffer. You are also inducing more drag at the foam/paint interface which means the pad is flexing more and heating up. The longer you work it, the more the problems increase and internal temperature of the pad goes through the roof.
Shorten your work times by about 500%. You will getter a better finish, better pad life and you'll be done faster
