Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Rupes 5 Inch 2000 & 3000 Grit Sanding Discs
Tested out the Rupes Sanding Discs using the Rupes Duetto and took some pictures to show them in action.
Rupes 5" Interface Pad
This goes between the backing plate and the sanding disc to provide flexible cushion which helps the face of the sanding disc to maintain uniform surface contact when sanding curved panels. It can also help reduce the aggressiveness of the sanding action.
Misting some water from a clean sources onto the panel...
The #2000 disc on the 12 millimeter orbit stroke Duetto cuts fast!
The #2000 sanded the panel down very fast...
D.O.I. = Distinction of Image
How well or clear an image is reflected.
Now take note of the DOI of the reflected florescent tube light on the panel.
Sanded clear paint turns white
Re-sand one half with #3000
Sanded...
Less cut = less paint build-up on the sanding disc....
Gloss and reflectivity coming back. - D.O.I. increasing
The side sanded with the #3000 Grit Rupes Sanding Disc will sand out faster and easier while keeping paint temperature lower.
#2000 Grit Side
#3000 Grit Side
Ready to re-sand the #2000 grit side and then buff-out the sanding marks.
The Rupes Sanding Discs are similar to the Mirka Abralon Sanding discs in form and function. I like the 5" diameter size as it makes these discs more usable for thin body panels as compared to the industry standard of 6" diameter.
On Autogeek.net
Rupes Polishers, Polishes and Pads
Sanded...
#2000 Grit Side
#3000 Grit Side
On Autogeek.net
