RUPES BigFoot LHR 19E Rotary Polisher Now in Stock & Ready to Ship!
Elliot@Autogeek
One of the most capable rotary machines on the market!
RUPES BigFoot LHR 19E Rotary Polisher is a high-torque, ultra-performing rotary polisher with a lightweight and compact design. It features all of the cutting power of a traditional rotary machine without the bulk and impaired maneuverability. Featuring an electronic speed control dial and progressive power trigger, the RUPES BigFoot LHR 19E Rotary Polisher is a welcome addition to both the RUPES BigFoot line-up as well as the world of rotary machines!
With a place in the world of automotive detailing, collision repair, marine detailing, and more, a rotary polisher can be one of the most versatile machines available. With the ability to remove even the toughest paint imperfections, a rotary machine is a necessary addition to any detailer’s supply closet. The RUPES BigFoot LHR 19E Rotary Polisher took all of these great qualities and packaged it into a sleek housing for one of the most capable rotary machines on the market today.
RUPES BigFoot LHR 19E Rotary Polisher features:
High torque motor – will remove swirls and scratches from paint quicker with a more efficient motor.
Dual transmission – will allow you to press the machine without slowing for additional corrective power.
Electronic speed control – clearly marks which speed is being used and is located on top of the machine.
Progressive trigger switch – allows you to fully control your speed with a slow start.
Lightweight and ergonomic design – far less bulk than other rotary machines, the RUPES BigFoot LHR 19E Rotary Polisher’s design allows for increased maneuverability and control.
Rubber tool rests – allows you to place the tool face up without damage to tool.
125 mm (5 inches) backing plate– smaller pads allow for higher precision during use without fear of overheating.
The RUPES BigFoot LHR 19E Rotary Polisher, thanks to the ingenious developers at RUPES, works best with their specially designed pads and products. For best results, it is recommended that the RUPES Rotary Foam Pads and the corresponding RUPES Rotary Chemicals are used with your RUPES BigFoot LHR 19E Rotary Polisher. Available in two sizes, these pads will fit perfectly into your growing RUPES collection!
When you’re looking for increased power for heavy paint imperfection removal, a rotary polisher is certainly the answer. When you want that same power with easier maneuverability and control? The RUPES BigFoot LHR 19E Rotary Polisher is the answer.
Technical Information:
Backing plate - 125 mm (5 inches)
Power – 1200 Watts
RPM – 450 – 1700
Weight – 4.85 lbs
Cord Length
– 29 ft.
Our Price: $359.00
