braga
- Mar 13, 2019
- 22
Hello, first of all, I'm new in polishing, learning how to use Rupes LHR15 Mark II everyday from morning till evening.
I have some issues (I think), but I'm not sure, my steps:
1. Clay the car.
2. Clean the surface with CarPro Eraser.
3. Put 4 small drops of Menzerna HC400 on the Rupes Blue Coarse Foam (for priming)
4. Level 2 for warm up the pad and spread the compound on the surface.
5. Put 2 more small drops of HC400, start compounding slowly. (Level 4)
6. Put the Rupes Yellow Fine Foam pad using Rupes Keramik (Yellow) and same steps (3 4 5)
I noticed, that surface or pad doesn't get hot, just slightly warm.
I tried to compound in the sun, and I did get better results, heat helped I guess.
Why the pad/surface is not heating up? Just slightly warm. Even HC400 is not dusting when I'm compounding in the shade, surface temperature is too low? Air temperature is only 52 °F.
Results, hood is really trashed, I polished it in direct sunlight. I guess I have to wet sand it or buy a microfiber/wool pads haha.
Last photo looks good to me, Rupes Blue foam + HC400 for compounding, Rupes Yellow foam + Keramik for finishing.
1. Clay the car.
