Rupes Duetto with 3" backing plate....What a perfect world it would be :)
Buracho
Member
Hello everyone!
So I came across a 3 inch backing plate for the Rupes LHR75 3 Pneumatic DA Polisher and I am wondering if it would fit the Duetto :props:
I am praying to the Gods it will fit the Rupes Duetto with little (washer mod) or no modification.
Has any one actually tried this??
It would be great if somebody with the Rupes 3 inch Pneumatic DA post dimensions of the backing plate. Thanks in advance.:)
Kamikaze make a 3 inch backing plate for the Duetto. I have one. It works good.:xyxthumbs:
^ This is pretty much what the LHR 75E Mini is plus the properly weighted counter balance and shroud.
The LHR 75E Mini backing plate can be modified slightly to fit onto the Duetto, but it will not be balanced. There is about a 100g difference in the weigh of it and the regular backing plate.
The Kamikaze one should be balanced. I wish Rupes made one!
It's called an LHR 75E Mini ;)
Thanks for the reply Guys. So I've checked out Kamikaze and they do make 3" BP for the Duetto:xyxthumbs: I am aware the Mini is just a Duetto with 3 inch pad ;) But versatility was what I had in mind here anyway Like @Mantilgh said if there is a 100g difference what Kamikaze obviously did was make the their BP 100g heavier right? Which is easy to do but I havent seen a replacement BP for the Mini on sale only for the Pneumatic one. Are they the same.
Can you confirm on the weight of the BP @Nicholls.
Thanks in advance. Cheers.
Dont forget any use of 3rd party backing plate voids the warranty that comes with the machine...Something to keep in mine.
Hmmm....good question. I think It certainly has the power to handle it and would be economical Atwell
Anyone?
So can you put a 5 inch bp on the mini ?????
Hmmm....didn't think of that. I think I has more than adequate Power to handel 5 - 5.5 inch pads and will be economical as well. Balancing is going to be an issue like Duetto tho.
Anyone care to input?
I have the 15, the Duetto and the Mini. As Mike Phillips has stated in the past, these tools are all part of a system. If you do this as a profession you'll have more than one tool as they are needed for different situations. If you're doing this as a hobby and don't have the extra cash for multiple machines I would suggest a PC or GG6 that you can use different LC BP's on. I wouldn't try to put a 3" BP on my Duetto or a 5" BP on my Mini. This isn't what they were designed for. Just a note, the mini has a smaller ring arounf the BP, if you put a 3" BP on a Duetto you don't necessarily get into tighter area because the bp ring is much wider and you will bump into things like mirrors etc.
Thanks for the reply. It makes total sense. I am a hobbies and I just wanted the best of both worlds:dblthumb2: haha
I will go with the Kamikaze then. Cheers
I'd post a picture of the 3" BP on the Duetto if the gallery wasn't acting up.
It probably won't help to much getting into tighter places, maybe just better for working on thiner areas like B-pillars.
I totally agree. That is what I panned to use it for. But for tight places I will use a rotary 3 or 2 inch pad and extension, that way you cover every inch and get precise cutting/polishing.
See what you can do posting the pic cause I am considering buying the lhr75e
But if I can just buy the duetto and use the 5 and 3 I'll just do that any change in performance when going 3
The problem with this would be that the mini BP + pad is lighter than the duetto's so you would needed to somehow reduce the weight of the duetto's BP so that it and the pad ends up weighing about the same as the mini's. I don't think it's possible.
Making the mini's BP heavier for use with a duetto is far easier. But then you have the larger shroud of the duetto getting in the way.
This is why I still prefer the porter cable type DA for polishing tight areas (even over the mini) if I'm not going to get the rotary out.
If anyone is after a 3" backing plate for the Rupes LHR12 or LHR15, give me a shout. I can make one on a 3D printer using very strong filament. This has been tested and works fine. The weight is within a few percent of the original so vibration is not an issue. This will allow you to use the BF100 range of Rupes pads. ����
Gee whiz, you're trying to sell backing plates on AG forum?
