DETAILROOKIE
- Jan 19, 2016
- 1,207
- 124
Hello everyone! I finally used my Rupes Ibrid for the first time and felt that it was severely underpowered. I tried all three movments and it barely cut and kept stalling with the 3mm and 12mm. I was using Rupes Yellow pad with Perfect Finish just to clean up light swirls in a tight spot, and it barely removed them until I used the rotary attachment. The panels were flat so I wasn't using it on any curves. Is this normal? I used the same pad and polish combo throughout the whole car, but should I have used a stronger polish when using the ibrid? Any advice would be great!
Thank you!
Sent from my SM-N960U using Tapatalk
Thank you!
