Rust stain removal?
MrHandWash
In regards to rust cleaning solutions, does anyone have some advice on order to clean them off? Good products, low ph solutions or non-ph that is good for removal off paint?
If you've already washed the car, but there's a good rust sediment area where the stain has run down the car. You let it sit to loosen the sediment, what is a good method of removing it w/ out scratching the paint (assuming your customer doesn't want a cut, polish, or wax afterwards).
I'm just looking for a non-abrasive way that would not leave scratch marks in the finish. I'm assuming spray it on, let it sit, hose it off and repeat if not satisfied?
If washing doesnt remove it then just use a clay bar or a paint cleaner.
