When I went to see it there were sprinklers on and they were hitting right where the stain is.. Its been sitting there a year.
That is definitely rust. Those panels are usually gel coat fiberglas very similar if not exactly like the finish on most fiberglass boats and can typically withstand a wool pad and rotary polisher which is what is likely the answer to removing this stain.Just a question...Are you sure that is REALLY rust? Aren't the side panels aluminum? The struts on the shade are powder coated? The 'thing' below the reefer is plastic?
From the pictures that looks more like yellow road paint spray.
Bill
Most APCs are fairly toxic, unless they are specifically marketed otherwise. If you have some ARO laying around, give it a try on a small spot after hitting it with water.
Maybe some CLR you can get locally (I'm not sure it they have a "safe" version yet, but I've seen two different versions of the product at Kroger).
Perhaps some Iron X will work?:dunno:
I would second the ARO... CLR is some nasty stuff... Works great but NASTY!
