Angus
- Jun 14, 2012
- 1,583
Friends, as hard as we work to keep our vehicles shine and clean, often our OEM license plate screws go overlooked and rust into painful little eye sores. I’m certainly guilty of letting this happen.
But enough is enough – today I decided to replace the rusting little menaces on my wife’s 2012 Subaru Impreza while at the same time adding a nice little anti-theft layer.
The oxidized culprits:
Corroded offenders removed:
License plate and mounting area cleaned:
New Stainless Steel Security Screws from Lowes (~$5):
I went with slightly longer screws then the OEM ones because I used spacer to keep the new license plate frame from touching the paint.
What makes these screws secure is without this hollow point star drive bit they can’t be removed:
(~$2.50, also from Lowes)
See the little hole in the middle:
Since I was going to trouble, simply replacing the screws wasn’t an option. The cheap-o license plate frame was starting to rust and needed to go as well:
With a brandnew stainless steel frame in hand, a quick layer of BLACKFIRE Wet Diamond Metal Acrylic Sealant is added, and the screws are secured & guaranteed not to rust out anytime soon:
Done!
Hope this little DIY helps free you from Rusty License Plate Syndrome too.
Done!
