Hi all
I am an old school hand polisher but after looking into autogeeks online I now am into the power tools.
Hi Rory,
Welcome to AutogeekOnline! :welcome:
I have a 2007 Mirada 33 ft RV. I am in the process of removing all the vinyl decals because of being old and peeling. After a lot of work they are off.
I purchased a Flex PE14-2-150 polisher and used Mequiars Marine Oxidation remover #49 to eliminate the oxidation.
That's a great rotary polisher, lightweight, quiet, compact in size.
Does your RV look like this?
I just purchased the Flex XC3401 and Britemax Perfect Prep Fine Polish to remove the swirls.
Do a test spot with this tool, the pad and the product and make sure you're getting the results you're hoping for and looking for before buffing out the entire RV. The below article explains how to do a Test Spot
How To Do a Test Spot
And this video walks you through it on a 1970 Chevelle although the principals apply for anything a person is going to buff out.
My next step is to use the Meguiars High Gloss Polish # 45. The guy who is designing the new decals said I have to wait because it cannot have any wax on it so the decals stick.
Meguiar's M45 is a non-abrasive polish and also body shop safe. The part about being body shop safe means it contains no silicone or any other ingredients that could contaminate a body shop. It also means this product is WATER SOLUBLE. It provides no protection like a wax. It is what Meguiar's calls a
Pure Polish
At least last time I checked and according to this thread on Meguiar's, it's listed as Body Shop Safe
Body Shop Safe or Not?
My point is, nothing you've listed that you're using so far is a WAX or SEALANT.
The Meguiar's compound is water soluble.
The Britemax polish is likely water soluble.
The Meguiar's M45 is water soluble.
So far you have not listed a wax in your process for your graphics guy to be concerned about.
That said, you NEED to wax or seal the surface to slow down and prevent future oxidation. The M45 is for creating gloss, not long term protection.
Make sense?
My question is: can I polish over the new decals without harming them?
Thank you,
Rory
There's no definitive definition for the word POLISH in our industry.
Some companies call their synthetic sealants a polish.
Some companies call their abrasive polishes a polish.
Some companies call their non-abrasive polish a polish.
I wouldn't use an abrasive polish over brand new or even old graphics.
I have used and would use a super high quality ULTRA FINE polish over graphics IF they need cleaning. Here's an example,
MIke Phillips said:
I've machine polished graphics using ULTRA fine cut polishes and super soft foam pads.
Here's an example...
COPO Camaro - Flex vs Rupes - Carbon Fiber Hood Extreme Makeover
Here's before
There are a number of companies that offer really high quality ultra fine polishes that I would deem safe for machine buffing lightly over glossy graphics and the RUPES Diamond Ultra Fine Polish is one of them.
In the above quote, when you say polish do you mean to use a wax or sealant over the graphics and the rest of the RV?
