Just had my car painted "British Racing Green", a Dark green metallic Jaguar color, by my High-School Autoshop teacher.
Congratulations.
What is the car?
The Paint came out pretty nice, but it still lacks that deep clarity due to the orange peel.
That's normal.
But he told me that he was only able to lay down two, "double wet coats" of clear.
I was part of a team of people that wetsanded, cut and buffed a 1949 Ford Woody that the painter only sprayed 2 coats of clear. We sanded the HECK out of that project and it came out great.
Sad to say, all the pictures were posted to a temporary discussion forum using Microsoft software that ended up being junk so the company dumped the forum and went back to vBulletin. I lost 3500 posts when this happened and all of the pictures and the write-up from this project. The company? Meguiar's.
The team?
Mike Pennington, Jason Rose, Kevin Brown, Tom McDonald and me.
The car was a streetrod that belonged to a Surfing Band, I might even have one or two of their CD's somewhere.
Point being, painters are different. Some painters lay down just as much paint in two heavy or wet coats as other painters would lay down in 3-4 coats.
I guess the clear I bought (1 gal. of PPG shopline) wasn't enough or something.
What is the car, that gives us an idea of the surface area.
But for a general rule of thumb: is the clear thick/safe enough to cut and buff?
I'd say yes but kind of depends on how large the car is. Are we talking about a Ford Excursion or a Ford Focus?
I'm planning to do the initial cut with 1500, then follow up with 2000 grit sandpaper,
The sanding plan is okay. I'm a fan of finishing out at higher grit levels like #3000 and #5000 just because it makes the compounding step faster and safer.
then buff out with m105 with LC yellow cut pad and finish on top with m205 and LC white polish pad.
This is where I would suggest using a wool cutting pad. Wool cutting pads cut color and faster as it relates to removing sanding marks.
You can do it with foam, especially if you finish out at a higher grit paper/disc, but it will
take longer and foam cutting pads when used with compounds on rotary buffers for heavy cutting
generate a lot of heat to the surface. Heat is NOT good for clearcoats. Despite what others in the forum world have been posting for decades.
Now how about a picture of that car!
