Safe to reuse spray bottles?
S4Dallas
So I had two empty bottles. One GG wheel cleaner and one GG window cleaner.
I washed each out for a good 5 minutes with hot water and soap.
Do you think they are clean enough and safe to reuse as spray bottles for my quick detail spray?
depending on the bottle, I re-use them after it's been cleaned thoroughly. i like the plain bottle look so i will take any labels off carefully if possible...
i do it with my all purpose cleaner bottles i get. I used to toss em out but ive stockpiled quite a few now so I just kept them. good sprayer on em and a good 16oz bottle for most stuff!
I reuse the bottles as well. Running a very dilute APC then IPA through them and let dry.
My favorite bottle to reuse are the Febreeze ones. The sprayer is a fine mist and works great for clay lube.
I was going to say to remove the labels so that in a moment of distraction, you don't accidentally put wheel acid on windows or something like that.
Just remember to have all of the required and
necessary "product-data-sheets" readily available,
if you're detailing as a Business entity.
To paraphrase:
"It's not nice to fool Big Brother"!
Depending on what was in the bottle before, and what is going in after, I will rinse my bottles with Kleen-Strip. Then soak in water for a few minutes before rinsing and refilling. Call me crazy, but the last thing I need is some spray wax residue or something along those lines mixed with a concentrated APC, wheel cleaner, etc.
If need be I put a sticker on the bottom of the bottle (ex:AW - aquawax / D101 - Megs APC, etc.) but all my bottles are separated so I know which are which...
