Safest way to remove spray paint???
cobrakillerta
What would be the safest and most efficient way to remove a streak of gloss black spray paint from a satin black factory painted surface without affecting the factory paint?
•IMO:
-The Safest bet would be to contact
DR. BEASLEY'S @773-404-1600.
-They are the foremost progenitor of
“all things matte” paint-care products.
I would test two small spots with lacquer thinner...
First, a small inconspicuous spot of the unaffected paint to see how it reacts. If that is successful, then a small spot of the gloss black to see if the lacquer thinner will dissolve it.
Use the results of those test spots to determine if you should proceed.
I'm talking a rag saturated with lacquer thinner, not actually flooding the surface.
